best way to repair engine tin/sheet metal cracks, Repairing engine tin |
lonewolfe |
Jan 22 2014, 04:15 AM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I've searched around quite a bit on here and other sites about the best way to repair engine tin or sheetmetal cracks. I know this must have been covered before because every 914 or VW for that matter I've ever owned has had at least some cracks in the engine tin somewhere.
I'm wondering if I should try welding these cracks up with a mig welder, braising them with a torch or some other method would be better. Any suggestions? What have you all done to repair your engine tins? Do you have any pictures of your repairs? Any information will be appreciated. |
MMW |
Jan 22 2014, 06:07 AM
Member Group: Members Posts: 152 Joined: 6-October 13 From: Northern NJ Member No.: 16,477 Region Association: North East States |
I would mig or tig weld them. Brazing will not hold up. Since the tins are very thin just use tack welds until a full weld is had. Like doing a body panel. Also a pc. of copper as a backer will help prevent blow through. Even a flattened copper pipe works.
lonewolfe |
Jan 22 2014, 07:12 AM
I would mig or tig weld them. Brazing will not hold up. Since the tins are very thin just use tack welds until a full weld is had. Like doing a body panel. Also a pc. of copper as a backer will help prevent blow through. Even a flattened copper pipe works. Thanks for your suggestions. I have a mig welder and a copper spoon. This stuff is all new. I have some scrap tin pieces that I can do a little practicing on. I was just afraid the mig would be too much for that engine tin. I couldn't find any info on what other people had done. |
MMW |
Jan 22 2014, 08:47 AM
You should be using .023/.025 wire on really thin stuff. You can get away with .030 or .035 but it makes it a little harder.
Jan 22 2014, 09:55 AM
I would mig or tig weld them. Brazing will not hold up. Since the tins are very thin just use tack welds until a full weld is had. Like doing a body panel. Also a pc. of copper as a backer will help prevent blow through. Even a flattened copper pipe works. Thanks for your suggestions. I have a mig welder and a copper spoon. This stuff is all new. I have some scrap tin pieces that I can do a little practicing on. I was just afraid the mig would be too much for that engine tin. I couldn't find any info on what other people had done. Its sheet metal. Mig it, grind down your welds, prime it and either powder coat it or paint it. Simple stuff to fix. Rich |
Mark Henry |
Jan 22 2014, 10:01 AM
I would mig or tig weld them. Brazing will not hold up. Since the tins are very thin just use tack welds until a full weld is had. Like doing a body panel. Also a pc. of copper as a backer will help prevent blow through. Even a flattened copper pipe works. Thanks for your suggestions. I have a mig welder and a copper spoon. This stuff is all new. I have some scrap tin pieces that I can do a little practicing on. I was just afraid the mig would be too much for that engine tin. I couldn't find any info on what other people had done. Its sheet metal. Mig it, grind down your welds, prime it and either powder coat it or paint it. Simple stuff to fix. Rich (IMG:style_emoticons/default/agree.gif) Don't obsess about it too much, you can barely see it in the car. The exception is the /4 top cylinder/head tins but even they can be hard to see. I've brushed on DuPont nason black and you can't tell when in the car. |
lonewolfe |
Jan 22 2014, 06:26 PM
You should be using .023/.025 wire on really thin stuff. You can get away with .030 or .035 but it makes it a little harder. That's a great tip about the .023/.025 wire. That I do not have so will pick some up. I really appreciate everyones great suggestions and quick response. Thank you! |
Lo-Fi Version | Time is now: 17th May 2024 - 09:13 PM |
