| HalfMoon |
Jan 23 2014, 03:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So, what's everyone's experience with CV joint gaskets?
How have these two gasket materials performed for us? |
| toolguy |
Jan 23 2014, 05:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
Seems to me cork would never work as it would squish out when the CV bolts are torqued. . I use the gray dense fiber material with a real light coating of silicon. . no seeping. .
| Mikey914 |
Jan 23 2014, 05:54 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Actually they are a material like cardboard that absorbs grease to create a "plug" .
Got them here if you want them- http://shop.914rubber.com/Porsche-914-CV-j...m?categoryId=-1 The cork could be used but I don't know why factory didn't. -Mark |
| Dr Evil |
Jan 23 2014, 07:39 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I dont use any anymore. I assemble, clean thoroughly, and put RTV on the outside. That way there is no squish and the bolts dont come loose.
| HalfMoon |
Jan 23 2014, 07:58 PM
I dont use any anymore. I assemble, clean thoroughly, and put RTV on the outside. That way there is no squish and the bolts dont come loose. Odd you should mention that. I'm thinking of this bizarre idea a good friend of mine came up with to prevent loosening of the bolts... He thought using slightly longer bolts and nyloks would be a cheap and effective alternative to wiring them. Crazy huh? Btw, you mean RTV on the outside of the assembled unit and not squished together right? |
| 914_teener |
Jan 23 2014, 08:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
(IMG:style_emoticons/default/WTF.gif)
Ah no. Between the CV and the stub axle and output flange on the tranny. There are a ton of threads on using the silly cone and new washers with the bolts when you put the CV and half shafts back together. |
| Dr Evil |
Jan 23 2014, 09:51 PM
RTV around the OUTSIDE of the joint of the CV and flange.
| HalfMoon |
Jan 24 2014, 12:38 AM
| Dr Evil |
Jan 24 2014, 08:18 AM
Nyloc is fine (IMG:style_emoticons/default/tongue.gif)
| Cap'n Krusty |
Jan 24 2014, 09:42 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I dont use any anymore. I assemble, clean thoroughly, and put RTV on the outside. That way there is no squish and the bolts dont come loose. Odd you should mention that. I'm thinking of this bizarre idea a good friend of mine came up with to prevent loosening of the bolts... He thought using slightly longer bolts and nyloks would be a cheap and effective alternative to wiring them. Crazy huh? Btw, you mean RTV on the outside of the assembled unit and not squished together right? Nyloc nuts would be fine, IF they had a flat surface on which to seat, and IF the bolts were long enough to allow the plastic to grip the bolts, and IF the threads were REALLY clean, and IF there were enough clearance. IMO, one of the only applications on a 914 where RTV can safely be used is in place of a CV joint gasket. The Cap'n |
| ChrisFoley |
Jan 24 2014, 10:01 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I'll continue using the stock gaskets.
Never had a failure, never had the bolts loosen when I torqued them properly. I don't consider RTV a suitable gasket substitute for such applications. |
| vw505 |
Jan 24 2014, 10:50 AM
Member ![]() ![]() Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
So your saying bolt the CVs on and smear the RTV on the out side of the joint and flang?
| Dave_Darling |
Jan 24 2014, 02:01 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I know a number of people (some pro mechanics) who don't use any gaskets on the CV joints.
I use the stock cardboard-ish ones. Nylock nuts might work to keep the bolts tight. Safety wire definitely works, and provides a good visual cue that they are torqued. Someone on the board I think still sells bolts drilled for safety wire. I have heard of people using slightly longer bolts and think jam nuts on the back side of the flange. You have to be able to get a wrench onto the jam nut, of course. And you probably need to get the back of the flange spot-faced in that area so the jam nut sits flat. The stock setup, when used correctly, seems to work pretty well for many of us. --DD |
Lo-Fi Version | Time is now: 17th March 2026 - 06:12 PM |
