need to shim throwout clutch fork.what size socket needed |
rosenfe |
Jan 26 2014, 02:55 PM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
i need to put a shim under the ball that fork sits in.what size socket and socket depth needed to clear the ball ,not much room in there?
type47 |
Jan 26 2014, 03:18 PM
errr, OK, I believe the ball flats (for wrench) are 13mm and probably need a deep well socket . The fork is held on the ball by a little clip held on the fork by a 6mm socket head bolt. so once the fork is off, an open end/box end wrench will prob fit... but I don't see how you'll access these with tranny installed and if tranny is already separated, access is easy... so there is alot of room... (IMG:style_emoticons/default/confused24.gif)
PS, if tranny installed, why not just drop the tranny alone? Support the engine and remove tranny. Search here for advice in old posts.... |
rosenfe |
Jan 26 2014, 03:27 PM
errr, OK, I believe the ball flats (for wrench) are 13mm and probably need a deep well socket . The fork is held on the ball by a little clip held on the fork by a 6mm socket head bolt. so once the fork is off, an open end/box end wrench will prob fit... but I don't see how you'll access these with tranny installed and if tranny is already separated, access is easy... so there is alot of room... (IMG:style_emoticons/default/confused24.gif) PS, if tranny installed, why not just drop the tranny alone? Support the engine and remove tranny. Search here for advice in old posts.... trans is out,i dont think there is enough meat for a box end wrench,its meant for a socket ,i dont have a deep one to figure out size,close to 13-14mm i think,but hoping to hear from someone whose taken it out to shim. |
tradisrad |
Jan 26 2014, 03:37 PM
You will need a 13mm deep socket. I recall having to make a special thin walled socket with the grinding wheel.
Where in Nor Cal? |
type47 |
Jan 26 2014, 03:42 PM
...i dont think there is enough meat for a box end wrench, its meant for a socket , Ah, sorry, didn't remember about the recess, it'd been a long time. Still don't remember thinning the wall of the socket anyway. Not too many applications on 914's of 14mm tools come to mind (valve adjust jam nuts only one I can think of now, maybe one other way back in the cobwebs...) |
rhodyguy |
Jan 26 2014, 04:23 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
try a 1/4" drive deep socket.
mrbubblehead |
Jan 26 2014, 05:53 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
its a 14mm deep. but you have to grind/thin down the first 3/8 of an inch on the end of the socket. so it will fit down the well.
Dr Evil |
Jan 26 2014, 06:42 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
14mm deep that needs the end beveled to fit in the recess.
rosenfe |
Jan 26 2014, 08:13 PM
Cap'n Krusty |
Jan 26 2014, 09:31 PM
14mm or 9/16" deep socket with a very deep contact area. Most sockets are broached pretty shallow, and won't clear the ball. I can get you a Snap On part number if you'd like.
The Cap'n |
Krieger |
Jan 26 2014, 11:42 PM
Advanced Member Group: Members Posts: 4,714 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I shimmed mine too. I also used some permatex ultra copper on the threads and washer.
JStroud |
Jan 27 2014, 09:19 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I shimmed mine too. I also used some permatex ultra copper on the threads and washer. Ok I'll bite, hasn't heard of this, what is the purpose or reason for shimming the ball, to compensate for wear (IMG:style_emoticons/default/confused24.gif) Jeff |
pilothyer |
Jan 27 2014, 09:29 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I shimmed mine too. I also used some permatex ultra copper on the threads and washer. Ok I'll bite, hasn't heard of this, what is the purpose or reason for shimming the ball, to compensate for wear (IMG:style_emoticons/default/confused24.gif) Jeff I believe it is to correct the geometry after a flywheel cut. |
rosenfe |
Jan 27 2014, 11:29 AM
I shimmed mine too. I also used some permatex ultra copper on the threads and washer. Ok I'll bite, hasn't heard of this, what is the purpose or reason for shimming the ball, to compensate for wear (IMG:style_emoticons/default/confused24.gif) Jeff I believe it is to correct the geometry after a flywheel cut. yes, i would like snap on part number for that socket. the purpose of shimming the ball is to move the throwout fork foward (i installed a new flywheel,clutch,)if there is not enough room to fully engage throwout bearing ,it increases the distance the arm can travel.im doing this while drivetrain is out to avoid having to take it out again and re adjust.if your clutch works fine ,then this is not an issue. |
Phoenix-MN |
Jan 27 2014, 11:32 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Jan 27 2014, 12:21 PM
14mm socket that needs to be ground down to fit. (IMG:style_emoticons/default/cheer.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423295.jpg) |
rosenfe |
Jan 27 2014, 12:33 PM
14mm socket that needs to be ground down to fit. (IMG:style_emoticons/default/cheer.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423295.jpg) now i have to buy a grinder at harbor freight,need one anyway.who designed such difficult access at porsche? |
Cap'n Krusty |
Jan 27 2014, 01:00 PM
Snap On "FMS14". It's a 14mm semi-deep 12 point chrome socket. No grinding. About 20 bucks. One recently sold under the old number ("S6122") on Ebay for around $4, and one under the new number went for around $9. You might look into other 12 point deep, or semi-deep sockets. What's important here is the "broach depth", the depth of the contact surface before the inside of the socket returns to a shoulder. You need the drive surface to be deep enough to clear the ball and engage the hex. I would be happy to loan you mine, but the round trip postage would nearly equal the cost of buying one for yourself.
The Cap'n |
Jan 27 2014, 01:59 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I shimmed mine too. I also used some permatex ultra copper on the threads and washer. Ok I'll bite, hasn't heard of this, what is the purpose or reason for shimming the ball, to compensate for wear (IMG:style_emoticons/default/confused24.gif) Jeff I believe it is to correct the geometry after a flywheel cut. yes that is correct. So, you should ask the machinist how much was removed to ensure you use the correct size shim. rich |
Dr Evil |
Jan 27 2014, 02:12 PM
Shim? Jeez, it aint that specific. Put another washer under it, put teflon tape on the threads as it will now leak with 2 washers under the pivot, and call it good. You just need to move it forward, you will not need to measure how far or any of that.
Lo-Fi Version | Time is now: 21st May 2024 - 11:07 AM |
