ISO link for zerk install trailing arms |
Trekkor |
Jan 30 2014, 03:03 PM
http://www.elephantracing.com/documents/91...trailingarm.pdf
The Elephant Poly Bronze are really great. I just finished some work on my trailing arms and had to be careful not to let the pivot shafts slide out when carrying them to my work bench. The bushings have great free play and do not bind. |
HalfMoon |
Jan 30 2014, 03:59 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
http://www.elephantracing.com/documents/91...trailingarm.pdf The Elephant Poly Bronze are really great. I just finished some work on my trailing arms and had to be careful not to let the pivot shafts slide out when carrying them to my work bench. The bushings have great free play and do not bind. All true, but to rich for my blood (IMG:style_emoticons/default/sad.gif) |
Trekkor |
Jan 30 2014, 07:13 PM
The PDF shows the exact location of the grease fittings.
HalfMoon |
Jan 31 2014, 12:11 AM
The PDF shows the exact location of the grease fittings. Yep, pretty much where the location is in pictures previously posted in this thread. Problem is the inner location can be clipiied off when removing the trailing arm unless one is very careful. Must take a look and see if the inner can be mounted topside the trailing arm and still easy accessable.... |
CptTripps |
Feb 7 2014, 07:30 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Anyone done this on the front too?
chads74 |
Mar 7 2014, 01:18 PM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
I ordered my bushing and I am thinking about finally getting around to installing, but then remembered I wanted to add the zerk while I am at it. Where is everyone getting the zerk fittings to put into the trailing arm?
HalfMoon |
Mar 7 2014, 01:29 PM
I ordered my bushing and I am thinking about finally getting around to installing, but then remembered I wanted to add the zerk while I am at it. Where is everyone getting the zerk fittings to put into the trailing arm? I got mine at the local auto parts store. 6mm as I remember. Cheap. Less than 5 bux for all four of them. |
chads74 |
Mar 7 2014, 01:47 PM
Thanks! Hope the store down the street has them.
matthepcat |
Sep 12 2014, 02:54 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Bumping an old thread.
Anyone have the Elephant racing rubber bushing tools? Seems crazy that you have to buy a set of tools with each set of rubber bushings you buy? I talked to them on the phone and they said I need the tools to install correctly.....even with a press. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:22 AM |
