fog lights in a 75/76, how hard to install |
ws91420 |
Jan 3 2005, 07:00 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
How hard to put fog lights in a 75/76 that has not had hem before? Were the cars prewired for them? How hard to cut the bumper hole w/o it looking like c**p? Have the switch and lights do I need brackets?
TheCabinetmaker |
Jan 3 2005, 07:04 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The wiring should be there. I've got 2 sets of rubber bumper covers with fog holes in them. If ya want one its yours.
Bleyseng |
Jan 3 2005, 07:06 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
IIRC the fogs mount on the bumper so its a real easy install if the bumpers off.
Geoff |
ewdysar |
Jan 3 2005, 07:20 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Me too! I want to do this too.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Any detailed info on this upgrade will be greatly appreciated.... Eric |
Chris H. |
Jan 3 2005, 08:40 PM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
General tip:
For anyone using their existing bumper, just make sure you have the mounting brackets on the metal piece that is under the bumper cover. Some '75-'76 cars did not have them for some reason. You can crawl under and shine a flashlight up into the underside and you should see them. The wiring should be there at the front of the car and also behind where the switch goes in the dash. The lights are the same as the ones used on 911s of the era so they should be easy to find. You can get replacement lenses pretty cheap too. It really improves the look of the car. |
scotty914 |
Jan 3 2005, 09:54 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
its very easy to do just take a sharp razor knife and cut out on the edge of the recess, its only like a 1/6 thick around the edge. i used 19 dollar walmart lights. my bird post shows what they look like. and if you want to convert the lights so the operate independant of the high low beam just read this bird post
hope this helps |
StratPlayer |
Jan 3 2005, 11:33 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I added these to my 76, got these from a guy in Germany.
Attached thumbnail(s) |
StratPlayer |
Jan 3 2005, 11:34 PM
on the car
Lo-Fi Version | Time is now: 9th June 2024 - 04:45 PM |
