| Mikey914 |
Feb 1 2014, 11:52 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
http://www.914world.com/bbs2/index.php?sho...660&hl=hand
These work with aftermarket shifters with modification, DEC has a picture. I have already machined the rod and the the plates. The lever is the last piece. This is one of the projects I just needed to wrap up. |
| ChrisFoley |
Feb 2 2014, 08:29 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Mark,
We need to talk. I've been working since the middle of last year to produce an inexpensive hand throttle kit. Planned release is this spring. |
| brant |
Feb 2 2014, 08:34 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,204 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I need one
| Kansas 914 |
Feb 2 2014, 11:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
I need one - if for no other reason too warm the beast up so it will idle - stupid carbs.. (IMG:style_emoticons/default/smile.gif)
So - YES - I am in for one. |
| Mikey914 |
Feb 3 2014, 01:02 AM
Kind of nice to be able to set it up enough to warm up. I haven't done much AX but I bet it's nice to not have to have the motor spool all the way up from idle.
| DEC |
Feb 3 2014, 07:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany
Hi Mark,
Nice to see that you make further with these parts |
| GeorgeRud |
Feb 3 2014, 12:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I'd be interested in one for my conversion car.
| Jonathan Livesay |
Feb 3 2014, 01:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None
One for a 914 and one for a 912.
| hcdmueller |
Feb 3 2014, 01:42 PM
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England
I need one.
| euro911 |
Feb 3 2014, 01:45 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
One for a 914 and one for a 912. There you go ... and advertize on the Bird Board (IMG:style_emoticons/default/idea.gif) |
| ConeDodger |
Feb 3 2014, 01:52 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,463 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Love that these are true to the original design. I wouldn't have it any other way on my car.
But now that I am going to a Motronic controlled six, I don't need one. Good luck Mark... |
| FlatIV |
Feb 3 2014, 02:00 PM
AP ![]() ![]() Group: Members Posts: 55 Joined: 4-May 06 From: Circleville, Ohio Member No.: 5,978 Region Association: None |
I would like one, please.
| Mikey914 |
Feb 3 2014, 02:14 PM
Looks pretty good so far18 units if I count correct looks like $99 is obtainable.
-Mark |
| Kansas 914 |
Feb 4 2014, 06:12 PM
I wonder how this will install with a center console...
| bdstone914 |
Feb 4 2014, 06:44 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| PotterPorsche |
Member ![]() ![]() Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Anyone have a picture of what it looks like installed. i'm on the fence
| Jonathan Livesay |
Feb 4 2014, 06:56 PM
I wonder how this will install with a center console... The lever fits in the slot in the front part of the shifter housing. Should not be a problem with a center console. Bruce Well that's a problem for the 912, I didn't think that out. That is where the heater control lever goes. Maybe an extension piece to mount it on the tunnel just behind the shifter? Kind of like where the heater control is on a 914? |
| Kansas 914 |
Feb 4 2014, 07:36 PM
I wonder how this will install with a center console... The lever fits in the slot in the front part of the shifter housing. Should not be a problem with a center console. Bruce Well that's a problem for the 912, I didn't think that out. That is where the heater control lever goes. Maybe an extension piece to mount it on the tunnel just behind the shifter? Kind of like where the heater control is on a 914? Since I am running headers and have no heat that would be perfect. |
| Brian_Boss |
Feb 6 2014, 03:49 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
If the final product is as accurate a reproduction as the one from your German guy, I would definitely take at least one.
FWIW, I wouldn't mind a higher price if that's what it took to make it original looking. Brian |
| Mikey914 |
Feb 7 2014, 12:17 AM
If the final product is as accurate a reproduction as the one from your German guy, I would definitely take at least one. FWIW, I wouldn't mind a higher price if that's what it took to make it original looking. Brian understood, This should look and function like factory, and as you can see other members have made adaptations for their applications. |
Lo-Fi Version | Time is now: 9th June 2026 - 09:42 PM |
