| jim_hoyland |
Jul 6 2014, 10:31 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,080 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Mark, Will this work on a rH drive ? The rod, hanger, and joint would be the same. The base that holds the armature may need some modification. I could probably make one custom as I made the bases. You need a right? -Mark I am asking in behalf of a friend; will let you know later. As it is, I have an order submitted for a regular LH drive car ( mine) BTW: nice work making these. A lot of attempts went down before you came through. |
| Mikey914 |
Jul 7 2014, 01:31 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Yes, it took awhile. There was a lot of cutting, forming, punching, turning, threading, plating and assembly. But finally got them done!
| jim_hoyland |
Jul 14 2014, 08:25 PM
Got my kit today; need instructions... (IMG:style_emoticons/default/smile.gif) nice work, all the parts appear in good order.
| Mikey914 |
Jul 14 2014, 09:03 PM
DEC did a nice write up.
Attached File(s)
How_to_install_the_Handgas_lever.pdf ( 2.5mb )
Number of downloads: 133 |
| jim_hoyland |
Jul 14 2014, 09:42 PM
Nice pics,; would like to see a little more. Perhaps someone can explain what they did and the problems that arise. I still have to figure out how to cut that slot in the base of my Rennshifter.....
| JmuRiz |
Jul 15 2014, 11:44 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,633 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Just ordered mine...I wish installing this stuff was as easy as ordering (IMG:style_emoticons/default/biggrin.gif)
Maybe one of these years I'll get around to installing... It should be great, like a motorcycle choke...wish the 356 had one. |
| PancakePorsche |
Jul 17 2014, 11:41 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Here's the deal- I had been buying these from a member in Germany. He has decided to stop making them. I've decided to tool up to make these as he has opted to discontinue. I have a carbed car and these are basically a choke / and way of setting your throttle to a base RPM as desired on the fly. Since these have a value I've decided to pick them up. It's a pretty simple set up, the only real cost is the stamping for the lever section. I have a few ideas that may reduce the cost to the $99 area, but I have to see how they work. I will have these in about 6 weeks, so who's interested? Cost is also a function of how many people want them. If I can do 30 units I will guarantee $99 price point. So who's in? I would like one of these if still available. Please advise. Thank you |
| Kansas 914 |
Jul 18 2014, 07:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
I have a Weltmeister short shift kit that has a plate under the base of the shifter. It raises the shifter about 1/2". I wondered if I will have clearance issues with the rod to the pedal?
| jim_hoyland |
Jul 18 2014, 07:42 AM
I have a Weltmeister short shift kit that has a plate under the base of the shifter. It raises the shifter about 1/2". I wondered if I will have clearance issues with the rod to the pedal? ![]() Doesn't the throttle lever assembly attach directly to the body and the plate goes over it. Looks like you'll need a slot cut into the plate for the lever to move ? |
| Kansas 914 |
Jul 18 2014, 07:58 AM
| euro911 |
Jul 18 2014, 08:21 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Do you still have a stock shifter in your possession, Jim?
Measure off of the bolt holes in the OEM to see where you'll need to slice the Renn ... |
| Mikey914 |
Jul 19 2014, 11:00 AM
Here's the deal- I had been buying these from a member in Germany. He has decided to stop making them. I've decided to tool up to make these as he has opted to discontinue. I have a carbed car and these are basically a choke / and way of setting your throttle to a base RPM as desired on the fly. Since these have a value I've decided to pick them up. It's a pretty simple set up, the only real cost is the stamping for the lever section. I have a few ideas that may reduce the cost to the $99 area, but I have to see how they work. I will have these in about 6 weeks, so who's interested? Cost is also a function of how many people want them. If I can do 30 units I will guarantee $99 price point. So who's in? I would like one of these if still available. Please advise. Thank you Still available, and I plan to continue to stock them, but end of the month the GB us over, I'm actually selling a little below cost, so the new price will be $160 after. Get them while you can save a few bucks. |
| Mikey914 |
Dec 17 2014, 11:26 AM
Pics added
Listed 3 "extras" in the classified but thought I should add to thread too. 2 still available at GB price Attached thumbnail(s) Attached image(s)
| colingreene |
Dec 17 2014, 02:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Can I get one? I need it very badly.
| Ruff914 |
Apr 6 2015, 03:45 PM
ARuff ![]() Group: Members Posts: 10 Joined: 6-October 14 From: CO Member No.: 17,983 Region Association: Rocky Mountains |
I'm a little late, but if they are still available I would like 2.
I have 2 914 race cars that need throttle warm-up help. Alan |
| Mikey914 |
Apr 6 2015, 11:20 PM
| wes |
Apr 7 2015, 05:28 PM
wes ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California
I got mine today (thanks Mark) and thought I saw something on the installation with the console though can't find it now. Has anyone done it with a stock console?
| Mikey914 |
Apr 7 2015, 05:46 PM
It requires some modification. I intend to do mine in a few weeks.
Mark |
| wes |
Apr 7 2015, 05:58 PM
Is the mod on the parts I bought or the console? I was thinking that someone mounted it on the side of the console somehow or?
| Mikey914 |
Apr 7 2015, 06:02 PM
You can easily modify the board on the bottom, it just takes a little time and patience.
Lo-Fi Version | Time is now: 9th June 2026 - 11:45 PM |
