Will the shifter bar be in the way?, Should I install the linkage back to the firewall |
PanelBilly |
Feb 1 2014, 07:26 PM
914 Guru Group: Members Posts: 5,808 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Waiting for the engine to be complete, I'm working on other projects. Can i install the shift linkage from the interior back to the firewall before I lift the engine in place or does the rod hanging out get in the way?
JStroud |
Feb 1 2014, 07:34 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
You can do that, the rod doesn't stick out far enough to get in the way.
Jeff |
stugray |
Feb 1 2014, 07:37 PM
If I recall correctly, you need to put in the shift rod before the engine.
I think I had to drop my engine mount bar after engine install because I couldnt get the bar in the tunnel. |
mrbubblehead |
Feb 1 2014, 07:59 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
dont forget to replace the firewall bushing. tangerine racing makes a great replacement.
rhodyguy |
Feb 2 2014, 07:05 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
ALL of the linkage bushings. be done with it.
SLITS |
Feb 2 2014, 07:49 AM
If I recall correctly, you need to put in the shift rod before the engine. I think I had to drop my engine mount bar after engine install because I couldnt get the bar in the tunnel. (IMG:style_emoticons/default/agree.gif) Heed the words. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:47 PM |
