Possible group buy: Gauging interest for..., ... Distributor block-off plug for those of us using crank fired ignition. |
BMXerror |
Feb 2 2014, 05:03 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I meant to post this up a long time ago, but never found the time. Now there's a potential need. I developed this part when I first did my SDS install, ran it for two years and it worked pretty great. It's an aluminum plug that plugs the port on the block for the distributor. This is great for anybody who is running some sort of crank fired ignition. I'm posting to see how much interest there would be in such a product for a group buy.
This is what I came up with originally. The boss with the o-ring goes down into the port to seal it off, and the hole on the other end goes over the stud that holds the distributor clamp. This was a first draft. There would be some updates, including some pretty anodizing((IMG:style_emoticons/default/wub.gif)) and a jacking screw for removal, but the basic idea worked very well. Price would probably be around $35 per part with anodize. Though that's not final, and if we can get a number of guys committed to a group buy, that price would likely come down. This thread is just to see if there's enough interest to make it worth my while. I'm hoping to get at least 20+ guys to sign up for this. Please reply if you would be interested. Thanks for your time. Mark D. |
ablesnead |
Feb 2 2014, 05:12 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
will definately buy one
ClayPerrine |
Feb 2 2014, 05:43 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Not to belittle your part, but why not use one of these...
(IMG:http://www.914world.com/bbs2/uploads_offsite/ecx.images-amazon.com-1143-1391384588.1.jpg) It's an expanding rubber plug, available at your local ACE Hardware. I used one for 2 years on my crank fired ignition before the pickup coil failed. |
JStroud |
Feb 2 2014, 05:57 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
McMark has these in stock at Original Customs, they even come with his logo on top. (IMG:style_emoticons/default/aktion035.gif)
Jeff |
BMXerror |
Feb 2 2014, 06:03 PM
McMark has these in stock at Original Customs, they even come with his logo on top. (IMG:style_emoticons/default/aktion035.gif) Jeff Really? I'm not seeing it. As a matter of fact, I'm not seeing any products. What am I missing? Mark D. EDIT: I'm reading something now about his FI systems only being available to engine build customers. |
McMark |
Feb 2 2014, 06:07 PM
Yeah, I've got about 50 made up. Your price is a little cheaper than mine, plus yours is anodized. (IMG:style_emoticons/default/wink.gif) If you wanna run a batch, doesn't bother me any. I made mine mostly for myself and my in-shop customers, but they are available.
BMXerror |
Feb 2 2014, 06:10 PM
Yeah, I've got about 50 made up. Your price is a little cheaper than mine, plus yours is anodized. (IMG:style_emoticons/default/wink.gif) If you wanna run a batch, doesn't bother me any. I made mine mostly for myself and my in-shop customers, but they are available. Is that laser etched? Looks nice! (IMG:style_emoticons/default/thumb3d.gif) My price may be cheaper because I would be machining these myself instead of commissioning them. Mark D. |
Mark Henry |
Feb 2 2014, 07:12 PM
Mine in the '67 bug is a upright fan, I use the dizzy hole for the oil fill. (IMG:style_emoticons/default/wink.gif)
Dtjaden |
Feb 2 2014, 08:44 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Mario at the Dub Shop has one available for $20.
I meant to post this up a long time ago, but never found the time. Now there's a potential need. I developed this part when I first did my SDS install, ran it for two years and it worked pretty great. It's an aluminum plug that plugs the port on the block for the distributor. This is great for anybody who is running some sort of crank fired ignition. I'm posting to see how much interest there would be in such a product for a group buy. This is what I came up with originally. The boss with the o-ring goes down into the port to seal it off, and the hole on the other end goes over the stud that holds the distributor clamp. This was a first draft. There would be some updates, including some pretty anodizing((IMG:style_emoticons/default/wub.gif)) and a jacking screw for removal, but the basic idea worked very well. Price would probably be around $35 per part with anodize. Though that's not final, and if we can get a number of guys committed to a group buy, that price would likely come down. This thread is just to see if there's enough interest to make it worth my while. I'm hoping to get at least 20+ guys to sign up for this. Please reply if you would be interested. Thanks for your time. Mark D. |
BMXerror |
Feb 3 2014, 08:15 PM
BMXerror |
Feb 8 2014, 04:21 PM
Gonna pull the trigger on this. There's enough interest to get it going. I'm not sure exactly what the time scheduling will be, but I'll hopefully have finished parts between the middle and end of next month. If there's any further interest please PM me. Also, please PM me what anodize color your interested in. I'm undecided on this point, and can probably do a couple different colors. Black, blue and red are the common ones. Here we go.
Mark D. |
jimkelly |
Feb 9 2014, 06:05 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
that is a pretty part - nice job.
Lo-Fi Version | Time is now: 19th May 2024 - 04:17 AM |
