914 Flywheel Pricing and Quality. |
tach |
Feb 3 2014, 06:01 PM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
What do you think of these flywheels for the price at $170.00? There are other vendors selling flywheels near this $170.00 price range. They are about $160.00 cheaper than some others that are online.
http://aapistons.com/shop/flywheels/vw-lig...mm-12v-222.html |
0396 |
Feb 3 2014, 06:26 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I just bought one. ..I asked another member here that also bought one and he had no issues/ problems. .
tach |
Feb 3 2014, 06:41 PM
Mark Henry |
Feb 3 2014, 08:07 PM
The thing that concerns me about the new one I got is I don't see one single balancing drilling anywhere.
They either got it perfectly balanced or it is not balanced at all. I really have my doubts on the perfect balance theory, but I let you know as I'm having it balanced (whole engine) within the next few weeks. |
0396 |
Feb 3 2014, 09:56 PM
I just bought one. ..I asked another member here that also bought one and he had no issues/ problems. . Thanks, Did you get a new clutch, pressure plate and a throw out bearing also? If so, where. Thanks again. As for clutch, European Motors...also I had the whole assembly balanced..no the fly wheel was not balanced as sold. |
McMark |
Feb 3 2014, 11:09 PM
I bought a conversion flywheel from them (Type 4 in a Type 1) and the boring around the crank was wrong, both ID and OD. So it wouldn't fit on the crank, and the seal would have worn out quickly.
But that is a different unit/design than their stock flywheel which I haven't used. I would recommend measuring carefully before use. |
0396 |
Feb 3 2014, 11:16 PM
I bought a conversion flywheel from them (Type 4 in a Type 1) and the boring around the crank was wrong, both ID and OD. So it wouldn't fit on the crank, and the seal would have worn out quickly. But that is a different unit/design than their stock flywheel which I haven't used. I would recommend measuring carefully before use. My type 4 flywheel is already bolted up to the crank/ case. No issue + I contacted another member here that is already utilizing it for some time with no known issue. |
cary |
Feb 3 2014, 11:20 PM
Another option ..............
http://www.europeanmotorworks.com/vw/type-4-flywheel.html No dog in the fight. Just info. |
0396 |
Feb 4 2014, 10:58 AM
Another option .............. http://www.europeanmotorworks.com/vw/type-4-flywheel.html No dog in the fight. Just info. Correct, just passing on info. Enjoy your day |
AfricanHijinx |
Feb 4 2014, 11:28 AM
Member Group: Members Posts: 132 Joined: 12-April 11 From: Snohomish WA Member No.: 12,928 Region Association: Pacific Northwest |
I just bought the clutch, pressure plate and throw out bearing from Oreillys for 274 shipped
Lo-Fi Version | Time is now: 19th May 2024 - 04:00 AM |
