Body Work Repair Advice Needed |
jkb944t |
Feb 4 2014, 06:22 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am getting ready to install a used sail panel and lower fender section. It is in great shape except for some internal rust from the foam weather stripping. There are only a few minor holes that extent to the outside of the panel.
I need suggestions on repairing this before I install it. Should I weld or braze the minor pin holes shut and then use a fiberglass body filler to fill the rest of the imperfections? The panel will then fill in the hole in the side of my 914 GT conversion project. Jeff B |
Lo-Fi Version | Time is now: 19th May 2024 - 05:25 AM |
