FS 1974 Porsche 914 2.0, FS 74 2.0 Investment Grade #'s Matching |
sda4property@gmail.com |
Feb 4 2014, 11:46 PM
SDA4PORSCHE Group: Members Posts: 64 Joined: 9-July 12 From: Los Angeles California Member No.: 14,651 Region Association: Southern California |
Original 2.0
#'s matching Car GA Engine Code 1) Less than 5 Owners with 38 Years of documented receipts 2) Original California Blue Plate car 3) Never been hit or wrecked 4) No rust or Leaks 5) New Super clutch kit from Pelican a) Pressure plate & Disc & bearing b) New Fly Wheel 6) New Clutch cable 7) New Alternator 8) New Battery 9) New CV's ( 4 ) Packed & greased 10) New Bursch exhaust 11) SSI stainless Steel Heat ex-changers 12) New Rear sway bar bushings 13) New struts all the way around 14) New Weltmiester rear Springs ( 180 = Stiff ) 15) New Fuel Lines front & back 16) New Cap / Rotor / Points & Plugs 17) New Engine Main seals for motor & Push rod tubes & Valve cover gaskets 18) Valve job & tune up / Major service 19) New shift bushings for Transmission 20 ) New Paint- Glass out 21) New Rubber All receipts in file. $10,000 in recent receipts in past 2 years. All work performed by Daniels Speed shop in Costa Mesa Car is located in Costa Mesa at California Porsche's for viewing & test drive $14,000.00 Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 11:11 PM |
