Show me your in dash radio installs, . |
wndsnd |
Feb 5 2014, 07:41 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I'm craving better sounds.
Thanks John |
wndsnd |
Feb 5 2014, 08:02 PM
Oops posted in wrong area, have mercy on me.
saigon71 |
Feb 6 2014, 07:38 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I wanted some better tunes as well, but didn't want anything to "flashy" in my teener. I don't need top notch sound...just wanted a decent system without a lot of modifications to my otherwise stock car. While not installed yet, I went with this receiver:
http://www.crutchfield.com/p_023HSI220B/Bl...nki-220-BT.html These speakers: http://www.crutchfield.com/p_107DXI651/Pol...dio-DXi651.html And 6 1/2" speaker panels from here: http://www.914ap.com/products.php |
wndsnd |
Feb 6 2014, 10:16 AM
Will there only be a speaker in passenger well?
TheCabinetmaker |
Feb 6 2014, 10:52 AM
No picks, but I just went thru this. I had no tunes but exhaust for over a year. Finally got tired of it. Installed a new Pioneer receiver, 1000w Boss amp and 10 cd changer in the front trunk, 250w kicker 6X8's in the oem pods. I just ordered an 8" sub for the front of the console. Sounds great even at hiway speeds. Less than 300 bucks total. happy happy
saigon71 |
Feb 6 2014, 01:42 PM
LotusJoe |
Feb 6 2014, 02:00 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
wndsnd |
Feb 6 2014, 02:12 PM
JVC NX-5000 (IMG:http://www.914world.com/bbs2/uploads/post-11085-1340759415_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/resources.jvc.com-11085-1391716845.1.JPG) That looks cool. Is the screen big enough to see and do you think it would fit in dash? |
LotusJoe |
Feb 7 2014, 05:56 PM
I will fit in the dash. It is a standard single DIN. Probably will require enlarging the dash if you have not had a single DIN radio before. there is enough depth behind the dash so that should not be an issue.
orthobiz |
Feb 7 2014, 06:11 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I'm considering an upgrade this summer, also. Back in the day, I had a Nakamichi head unit, no amplifier, with a cassette deck (hey, it was the 80's). It fed a Harman Kardon power amp that supplied a pair of Dahlquist car speakers. It was great, but the speakers need a minimum of 30 watts RMS, better with a little more.
I have bought a vintage pair of the Dahlquists, they fit easily into the regular speaker pod area with minor modification. But I can't seem to locate a new head unit, or "dead head" as they are sometimes called. Everything seems to have a four channel amp built in. These speakers need a fair amount of power and I'm concerned that the 42x4 or 50x4 "peak" wattage units that are the norm for today will not supply enough. For instance, a 50 watt peak unit could mean only 20 watt RMS. Can't believe they don't give the RMS ratings only! So, who still sells a head unit without an amplifier? Paul |
orthobiz |
Feb 7 2014, 06:12 PM
I will fit in the dash. It is a standard single DIN. Probably will require enlarging the dash if you have not had a single DIN radio before. there is enough depth behind the dash so that should not be an issue. BTW Joe, that install looks great! Hope all is well with you! Paul |
Mike Bellis |
Feb 8 2014, 10:21 AM
If you do find something you like on Crutchfield, search the same model number on ebay and save money.
I just looked at a Kenwood KDC-655U. $149+ shipping on Crutchfield, $109+ free shipping on ebay. Both new in the box. Just found another on ebay for $97-free shipping... Crutchfield is a good resource but expensive some times. |
CptTripps |
Feb 8 2014, 12:01 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I do the same thing, but a different way.
Search Crutchfield for the best reviewed stuff. They are normally discontinued. Just got a JVC KW-NX7000 Nav system with Bluetooth for $250 shipped. Crutchfield $229: http://www.crutchfield.com/S-kueVSpE1YUP/p...ker-KS65-2.html Just got on eBay for $69: http://bit.ly/1o4PTWD (IMG:style_emoticons/default/smilie_pokal.gif) |
wndsnd |
Feb 8 2014, 03:47 PM
How about this?
Bluetooth, and battery powered, good for 7 hours or can be hardwired. Leave everything stock Pair this with my smart phone, and add Pandora app. Place on dash, or on console between seats. John |
wndsnd |
Feb 8 2014, 04:07 PM
wndsnd |
Feb 8 2014, 07:48 PM
I am loving this little set up. Can't wait to try in the car. It has impressive big sound....
CptTripps |
Feb 8 2014, 08:01 PM
wndsnd |
Feb 8 2014, 08:33 PM
CptTripps |
Feb 8 2014, 09:53 PM
Sorry. I just don't want you to get your hopes up. I have a Jawbone Jambox that I use every day. It'd never work in a car though.
ruby914 |
Feb 9 2014, 12:47 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I just replaced the first 20 year old amp that I put in the door last year.
It had a loose connection. It may be from shutting the door but the amp is so close to the hing, I think an amp should be able to handle that with out too much problem. Heat was another concern. If this one goes out maybe it is not a good place for the amp. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:14 PM |
