MY 75/76 catalytic converter control, Placing of catalyst temperature sensor and relais |
wolle914 |
Feb 9 2014, 07:39 AM
Newbie Group: Members Posts: 5 Joined: 9-February 14 From: Munich, Bavaria, Germany Member No.: 16,979 Region Association: Germany |
My 914 2.0 of MY 76 was tranferred from Texas to California in 1985 and was converted to the Californian emission control standard (Catalyst, EGR). However, the temperature sensor for the catalyst and the related relais as well as the indicator lights were never installed. I now want to complete this work and need a picture of a rear trunk of a 75 or 76 model showing the installed relais below the interior part of the left tail light housing as well as the placing of the wiring harness from the relais to the catalyst. Where is this harness passing throught the base plate of the rear trunk ? Can anyone post a photo ? Thanks !
wolle914 1976 914 2.0 2000 Boxster S 2011 Cayenne Diesel |
Krieger |
Feb 9 2014, 05:36 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I removed this harness years ago from my 75. It is overspayed in red paint so its fairly easy to see. Not plugged to chassis harness on right side of photo. The chassis harness has the plug built in (white). Folding metal tab to hold the harness to body- below and right of trunk latch mechanism. The relay is in the correct position. There is a single screw hole in the body to mount the relay.
Attached thumbnail(s) |
Krieger |
Feb 9 2014, 05:37 PM
Here is the hole to mount the relay.
Krieger |
Feb 9 2014, 05:39 PM
The hole is 16mm wide and 84mm from the trunk latch/bulkhead to the center of the hole. My 72 does not have this hole or the folding metal tab. (IMG:style_emoticons/default/beer3.gif)
wolle914 |
Feb 10 2014, 01:47 AM
Hello Krieger:
thank you very much - the pictures will help me to authentically install the relais and the wiring harness. wolle914 (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 02:31 PM |
