Advice on master cylinder change |
sixaddict |
Feb 9 2014, 07:43 PM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Sorry if this has been covered...
Changing master ; do filler lines get pushed in or do I need to pull out rubber inserts , push on to lines then reinstall. Don't feel I am getting them in all the way. Thanks |
CptTripps |
Feb 9 2014, 07:56 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Mine pushed into the rubber things.
Not sure if I ever did one where I pulled them out first. That may be one way to do it though. |
Cap'n Krusty |
Feb 9 2014, 07:57 PM
Washer. Grommet. Metal lines. Put them in AFTER the washer and grommet are installed. I use small vise grips and a hooked puller.
The Cap'n |
jimkelly |
Feb 9 2014, 08:14 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
yeah - sometimes, less pressure gets them in, vs, the fierce pressure you MAY feel is needed.
yeahmag |
Feb 9 2014, 09:41 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I gave up after 3 attempts and pulled the grommets out and put them on the lines per the Pelican article.
euro911 |
Feb 10 2014, 01:22 AM
Try seating the supply lines before bolting the MC up. You may need to unbolt the reservoir to give you enough slack.
sixaddict |
Feb 10 2014, 07:03 PM
Thanks all.... Last time I go so irritated I left loose and let the shop do it.......refuse to do that again........I think!
sixaddict |
Feb 12 2014, 11:29 AM
MC bought from major 914 vendor......has no "washers"
Anybody know for sure if that is an "issue".........would like a "second" opinion from someone who knows for certain. Thanks |
Cap'n Krusty |
Feb 12 2014, 11:55 AM
Yes. Get them from the old one. Did the new one (you bought "Ate", right?) come with the rubber grommets? Note: If you bought a Chinese master cylinder, you'll have a chance to get really good at the R&R and bleeding procedures, IF you live through the brake failure ...............
The Cap'n |
bulitt |
Feb 12 2014, 02:38 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
sixaddict |
Feb 12 2014, 03:03 PM
Pulled grommets
They were not there Called and asked ....of course "no worries" MC bought from major 914 vendor......has no "washers" Anybody know for sure if that is an "issue".........would like a "second" opinion from someone who knows for certain. Thanks If the MC came with grommets the washers may be under them. Take a look. |
Feb 12 2014, 03:15 PM
914-6 GT in waiting Group: Members Posts: 19,294 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My ate mc came without washers under the grommet. I reused the washers from my old mc. I would not leave them out
Lo-Fi Version | Time is now: 27th May 2024 - 11:32 AM |
