sixaddict
Feb 9 2014, 07:43 PM
Sorry if this has been covered...
Changing master ; do filler lines get pushed in or do I need to pull out rubber inserts , push on to lines then reinstall.
Don't feel I am getting them in all the way.
Thanks
CptTripps
Feb 9 2014, 07:56 PM
Mine pushed into the rubber things.
Not sure if I ever did one where I pulled them out first. That may be one way to do it though.
Cap'n Krusty
Feb 9 2014, 07:57 PM
Washer. Grommet. Metal lines. Put them in AFTER the washer and grommet are installed. I use small vise grips and a hooked puller.
The Cap'n
jimkelly
Feb 9 2014, 08:14 PM
yeah - sometimes, less pressure gets them in, vs, the fierce pressure you MAY feel is needed.
yeahmag
Feb 9 2014, 09:41 PM
I gave up after 3 attempts and pulled the grommets out and put them on the lines per the Pelican article.
euro911
Feb 10 2014, 01:22 AM
Try seating the supply lines before bolting the MC up. You may need to unbolt the reservoir to give you enough slack.
sixaddict
Feb 10 2014, 07:03 PM
Thanks all.... Last time I go so irritated I left loose and let the shop do it.......refuse to do that again........I think!
sixaddict
Feb 12 2014, 11:29 AM
MC bought from major 914 vendor......has no "washers"
Anybody know for sure if that is an "issue".........would like a "second" opinion from someone who knows for certain.
Thanks
Cap'n Krusty
Feb 12 2014, 11:55 AM
Yes. Get them from the old one. Did the new one (you bought "Ate", right?) come with the rubber grommets? Note: If you bought a Chinese master cylinder, you'll have a chance to get really good at the R&R and bleeding procedures, IF you live through the brake failure ...............
The Cap'n
bulitt
Feb 12 2014, 02:38 PM
QUOTE(sixaddict @ Feb 12 2014, 12:29 PM)
Thanks
If the MC came with grommets the washers may be under them. Take a look.
sixaddict
Feb 12 2014, 03:03 PM
Pulled grommets
They were not there
Called and asked ....of course "no worries"
QUOTE(bulitt @ Feb 12 2014, 12:38 PM)
Thanks
Feb 12 2014, 03:15 PM
My ate mc came without washers under the grommet. I reused the washers from my old mc. I would not leave them out
