Sold the Dog, and going to build a historic racing 4 |
Downunderman |
Feb 11 2014, 12:09 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
After about 16 years and a restoration and many tarmac rallies and race meetings I have sold it. Its gone to a good home (he already has two or three).
I have found a couple of 4's sitting in a shed in Melbourne which I will have a look at in a few weeks time when I am down at the Phillip Island historics. One or other should make a good base for a historic racer. Here's the issue for you blokes; I am limited to a 1.7 plus 1.5mm bore increase, so about 1740cc all up. I can use the existing injection or carbs. I need will need about 170hp out of it. Obviously a lot of revs and compression, but what internals, heads etc?? Whilst I have to use all steel body panels I can use plastic windows and should be able to get the weight down to about 800kg. BTW, does anyone have any photos of cars competing in the era (early 70's) with the windscreen chopped off? That might be an option to get rid of a bit of weight and windage. Photo of the Dog in its most recent Rennesport meeting livery last year. Cheers, Attached image(s) |
campbellcj |
Feb 13 2014, 09:20 AM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Great-looking car there. I hope the new owner treats her well!
Search the web for "Ginther 914" or "Ginther windscreen" images and I think you'll find some ideas re. the chopped front. I don't know how much weight it loses though. Obviously if you have a full rollcage and other safety equipment, it adds back a lot of the weight lost by gutting and removing or swapping glass windows for plastic. |
brant |
Feb 13 2014, 09:52 AM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
170hp is not going to work with stock fuel injection.
brant |
Feb 13 2014, 09:58 AM
Is 800kg the rule? You should be able to get down to 750kg. Or even 725kg.
Stay away from over bracing. Be innovative and consider 4 lug without venting. Look at my build thread too |
Downunderman |
Feb 14 2014, 12:23 PM
It will be as light as it can within the rules. There is no minimum weight, but judging from what the 6 weighs 800kg or less should be achievable. I'm not intending to put any bracing in the body; the cage will do that. It has to stay 4 lug, so thats simple.
I didnt expect the the stock fuel injection would work. It might need some "assistance". Cheers, |
brant |
Feb 14 2014, 01:11 PM
it certainly is a cool project
I've actually been thinking about building another -4 race car similar... ginther screen and all 170hp is going to be the tough part everything else is doable most of the guys running race 1.7's here are in the 120hp range I know Jake and others have built 100hp/L race motors but I think those are probably $15,000 to $20,000 motors so it is not a "easy or cheap" goal to attain I'm playing with the idea of a legal 2.0-4 with 140hp and 1625lbs on slicks. I bought the chassis (stock in need of all of the race prep) and I bought the ginther screen. I have a core motor... I just need another 40grand and 6 months off of work paid... no problem |
stownsen914 |
Feb 15 2014, 10:50 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I didnt expect the the stock fuel injection would work. It might need some "assistance". I don't think there is anything about the stock injection that will get you anywhere near 170 hp. The throttle body and runners are too small, and the electronics are not worth trying to tune. I think you probably have some carbs in your future. Sounds like a fun project. Have a blast with it! Scott |
Lo-Fi Version | Time is now: 29th April 2024 - 08:07 AM |
