bajafreaks |
Member ![]() ![]() Group: Members Posts: 107 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California ![]() |
The 74 I just bought doesn't have the original engine, how do I know if this car came with a 1.8 or 2.0 ??? vin#4742906720
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Porsche did not make a list public that has a connection between engine and VIN. And the emission information label in 74 was on the engine fan housing. I have heard you can call Porsche and they can look up info but you may have had to order a COA first, I don't know.
You say it has a non original engine, how do you know? What is in it now, engine, FI, Carbs? This is a long shot but depending in what has been done in the engine compartment you may find a clue. The 1.8 engine came with L-jet FI and they had a bracket for the Air Filter/Air Flow Meter that attached to the driver side inner long, the bracket would likely have left marks on the long if it had been there. Of course if the engine compartment has been repainted or something, probably not. Are you wanting to restore to original? Any year/size 914-4 engine can be put in any year 914-4, they are essentially plug & play. Good luck Jim |
bajafreaks |
Porsche did not make a list public that has a connection between engine and VIN. And the emission information label in 74 was on the engine fan housing. I have heard you can call Porsche and they can look up info but you may have had to order a COA first, I don't know. You say it has a non original engine, how do you know? What is in it now, engine, FI, Carbs? This is a long shot but depending in what has been done in the engine compartment you may find a clue. The 1.8 engine came with L-jet FI and they had a bracket for the Air Filter/Air Flow Meter that attached to the driver side inner long, the bracket would likely have left marks on the long if it had been there. Of course if the engine compartment has been repainted or something, probably not. Are you wanting to restore to original? Any year/size 914-4 engine can be put in any year 914-4, they are essentially plug & play. Good luck Jim I was told by the seller that it had a bus engine in it so I looked up the engine id and its for 80-83 vanagon. It has carbs now. I'll really just curious which engine the car came with and yes I do realize their interchangeable. |
Lo-Fi Version | Time is now: 10th July 2025 - 06:47 PM |
