> 1974 1.8 or 2.0
bajafreaks
post Feb 12 2014, 09:35 PM
The 74 I just bought doesn't have the original engine, how do I know if this car came with a 1.8 or 2.0 ??? vin#4742906720
Cap'n Krusty
post Feb 12 2014, 10:36 PM
Cap'n Krusty
The engine you think you have is substantially different from other Type 4 based engines, and it's unlikely to be in your car. Let's see a picture of the top of the engine .........
The Cap'n
bajafreaks
post Feb 12 2014, 11:08 PM
QUOTE(Cap'n Krusty @ Feb 12 2014, 08:36 PM) *
The Cap'n
The number on the engine is CV0444076 and when I looked it up it stated 80-83 vanagon 2.0Attached Image
JFJ914
post Feb 13 2014, 09:34 AM
QUOTE(bajafreaks @ Feb 13 2014, 12:08 AM) *
The Cap'n
See the red rectangle on the drivers sidewall? Is the emissions sticker under the red paint? Try to clean the sticker carefully, I used brake cleaner, and see what it says.
Cap'n Krusty
post Feb 13 2014, 12:44 PM
Cap'n Krusty
QUOTE(John Jentz @ Feb 13 2014, 07:34 AM) *
The Cap'n
It is, indeed, a Vanagon motor. Prone to meltdowns when the EGR system is disabled. In this case, removed. Probably be OK with carbs, probably not with FI. How do you add oil? Vanagons used a lower block mounted oil filler unit, which would interfere with the alternator and the tin. I see they solved the dipstick issue with that contraption sticking way up in the middle of the engine compartment. Interesting ...................
The Cap'n
bajafreaks
post Feb 13 2014, 12:56 PM
QUOTE(Cap'n Krusty @ Feb 13 2014, 10:44 AM) *
The Cap'n
The Cap'n
If you notice there is a rubber line about 1/2" in diameter near the coil, its screwed into to the top of the engine case I'm assuming that's where you could add oil...definitely strange. The more I investigate the more I think Id be better off trying to find the correct engine.
bajafreaks   1974 1.8 or 2.0   Feb 12 2014, 09:35 PM
billh1963   The 74 I just bought doesn't have the origina...   Feb 12 2014, 09:53 PM
bigkensteele   Is it close to factory correct show level, or do y...   Feb 12 2014, 09:59 PM
jcd914   Porsche did not make a list public that has a conn...   Feb 12 2014, 10:07 PM
bajafreaks   Porsche did not make a list public that has a con...   Feb 12 2014, 10:19 PM
Cap'n Krusty   The engine you think you have is substantially dif...   Feb 12 2014, 10:36 PM
bajafreaks   The engine you think you have is substantially di...   Feb 12 2014, 11:08 PM
John Jentz   [quote name='Cap'n Krusty' post='1997302' dat...   Feb 13 2014, 09:34 AM
Cap'n Krusty   [quote name='Cap'n Krusty' post='1997302' da...   Feb 13 2014, 12:44 PM
bajafreaks   [quote name='John Jentz' post='1997467' date='Feb...   Feb 13 2014, 12:56 PM
bajafreaks   See the red rectangle on the drivers sidewall? Is ...   Feb 13 2014, 03:26 PM
dlkawashima   It reads engine size 120 CID In that case, you...   Feb 13 2014, 06:49 PM
bajafreaks   [quote name='bajafreaks' post='1997610' date='Feb...   Feb 13 2014, 07:53 PM
Spoke   Didn't they put a 1.8 or 2.0 emblem on the rea...   Feb 13 2014, 10:09 AM
bajafreaks   Didn't they put a 1.8 or 2.0 emblem on the re...   Feb 13 2014, 10:57 AM
dlkawashima   Do you know if your car has its original gas tank?...   Feb 13 2014, 12:18 PM
bajafreaks   Do you know if your car has its original gas tank...   Feb 13 2014, 12:53 PM
Dave_Darling   I believe that the 1.8s also came with that size. ...   Feb 13 2014, 12:58 PM
Jeff Bowlsby   120 CID = 2-oh!   Feb 13 2014, 06:33 PM
914_7T3   Great info on the expansion tank decals here. I a...   Aug 13 2019, 12:28 PM
Superhawk996   Great info on the expansion tank decals here. I ...   Aug 13 2019, 12:35 PM
bbrock   Great info on the expansion tank decals here. I ...   Aug 13 2019, 09:13 PM
914_7T3   [quote name='914_7T3' post='2738033' date='Aug 13...   Aug 13 2019, 11:38 PM
914Sixer   I thin AA has reproduced your labels already.   Aug 13 2019, 12:33 PM
914_7T3   I thin AA has reproduced your labels already. ...   Aug 13 2019, 08:40 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:44 PM
