Front anti-sway bar, Dimensions |
914work |
Feb 13 2014, 10:05 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
In restoring a couple cars I've encountered a few different sway bars both aftermarket and OE.
But the OE bars appear to have come in different dimension most likely from different applications, 911/912 & 914. Obviously the bar thickness or diameter but also the length of the link connecting the A-arm to the lever arm. Does anyone know the correct link length (eye to eye) for the 914 vs others? |
bdstone914 |
Mar 19 2014, 08:12 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
In restoring a couple cars I've encountered a few different sway bars both aftermarket and OE. But the OE bars appear to have come in different dimension most likely from different applications, 911/912 & 914. Obviously the bar thickness or diameter but also the length of the link connecting the A-arm to the lever arm. Does anyone know the correct link length (eye to eye) for the 914 vs others? 914's use the shortest drop links. LWB 911's use a link 3/4" longer and SWB cars use one 3/4 inch longer than LWB cars. Bruce |
Lo-Fi Version | Time is now: 2nd May 2024 - 08:59 AM |
