Need a measurment, for front anti-sway droplinks |
Dave-O |
Jan 5 2005, 02:12 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Hey all,
This is for my fabricated front sway bar. What is the range of adjustability of the standard adjustable drop links (welt, tarret, smart, etc.) from the center of one hole to the center of the other hole? Another quick question... How does this range work for slightly lowered 914's? Should they be any shorter/longer? I'm having some parts machined and i don't have my 914 around to measure. Gotta love the campus machine shop, they're doing the work for free! thanks in advance, David |
MartyYeoman |
Jan 6 2005, 03:34 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
This is a linkage design I've been working on.
It contains a rotatable blade section for tension adjustment. The geometry does not change over the adjustment range. The horizontal dimension is 4.75" (same as stock). The vertical dimension is 7.43" (also, same as stock) What do you think? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 09:52 AM |
