One more piece in the 6x6 project, 6 speed showed up today |
a914622 |
Feb 13 2014, 07:46 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Sweet I got the suby 6 speed today. Cable shift, limited slip and 6 gears! (IMG:style_emoticons/default/smash.gif)
Now this just got a lot more fun!! Attached thumbnail(s) |
David J |
Feb 13 2014, 07:55 PM
Newbie Group: Members Posts: 29 Joined: 18-June 12 From: Dallas Member No.: 14,577 Region Association: Southwest Region |
Can the Subie 6 speed be converted to 2WD with the Subaru gears kit or is it a different process?
CptTripps |
Feb 13 2014, 08:16 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I've heard Yes...and I've heard No.
Never seen one completed though. (At least I don't think any of the builds I know are 6-sp) |
a914622 |
Feb 13 2014, 09:16 PM
Yes same idea but bigger splines. I'm going to be making the swap stuff. The gears are a little wider than the 5ers and I think the shafts are bigger. Same length as a 5. 2inch longer than 915.
I have a 5 speed on the stand to compare to . |
skeates |
Feb 13 2014, 10:38 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
let me know if you need any blow-up diagrams for the tranny. I've got the FSM for the 2010 Outback and they happened to offer it with the 6 speed.
a914622 |
Feb 14 2014, 08:19 PM
Thanks for the offer but it's already apart. First thing I'm working on is trying to make the center diff run backwards. I think I can make it work in the vanagon without spending 1500.00 on gears. I also have an end nose drawen up for the 5 that has the 914 ears on it and the end plate for the vanagon on it. I'm going to try to incorporate the cable shift like the 6 and make one.
Jeff |
Lo-Fi Version | Time is now: 28th May 2024 - 07:00 AM |
