Removing Front Caliper Pistons |
lennyhope |
Mar 1 2014, 03:16 PM
Member Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
I've got some rust on sticking issues on the front calipers. I have the pistons now both pushed out facing each other after putting a compressor on them. They are still removable. Do I b=need to take the caliper apart (split in half) to remove and clean th episton and barrel??
type47 |
Mar 1 2014, 04:29 PM
No. If the pistons are out enough just remove but don't split calipers. Don't use anything on the pistons that would scratch the cylindrical surfaces.
zambezi |
Mar 1 2014, 05:26 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
I've had good luck spraying the exposed portions with PB blaster and pushing them back in then using the air and a block of wood to pop them back out. Sometimes it takes a couple back and forth motions to get them all the way popped out. Definitely use a piece of wood for the piston to land on when it pops out and keep your fingers clear.
Lo-Fi Version | Time is now: 13th May 2024 - 04:37 PM |
