lennyhope
Mar 1 2014, 03:16 PM
I've got some rust on sticking issues on the front calipers. I have the pistons now both pushed out facing each other after putting a compressor on them. They are still removable. Do I b=need to take the caliper apart (split in half) to remove and clean th episton and barrel??
type47
Mar 1 2014, 04:29 PM
No. If the pistons are out enough just remove but don't split calipers. Don't use anything on the pistons that would scratch the cylindrical surfaces.
zambezi
Mar 1 2014, 05:26 PM
I've had good luck spraying the exposed portions with PB blaster and pushing them back in then using the air and a block of wood to pop them back out. Sometimes it takes a couple back and forth motions to get them all the way popped out. Definitely use a piece of wood for the piston to land on when it pops out and keep your fingers clear.
