Sun visor rebuild group buy need to do 20 sets, with mirror installed from $104 +shipping CLOSING 4/13 |
Mar 13 2014, 06:48 AM
914-6 GT in waiting Group: Members Posts: 19,240 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mark. I have a couple sets headed your way. Thanks
SKL1 |
Mar 13 2014, 09:58 AM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Out of town until this weekend but will get them out early next week. Have printed out the "order" sheet off your webpage as requested.
andys |
Mar 13 2014, 01:19 PM
Mark,
I don't see where you responded to the up side down mirror flap issue. Andys |
mdelwiche |
Mar 13 2014, 01:34 PM
Vegas_914 Group: Members Posts: 59 Joined: 17-March 12 From: Tucson, AZ Member No.: 14,266 Region Association: Southwest Region |
I'm in for a set as well. I'll stripping them down to the cores this weekend and then sending them out!
I have one extra set if someone is looking for some |
Mikey914 |
Mar 13 2014, 09:36 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Mark, I don't see where you responded to the up side down mirror flap issue. Andys We do have a clearance issue that would require moving the position of the mirror up to accommodate. We will be producing all visors as shown with the exception of the one that has been specified. As it gets more difficult with more options, and more opportunity to have problems any further requests for the flap on the opposite side will cost the same price as these were when we did the last group buy. $125 per set. |
Mar 14 2014, 07:01 AM
Mark, I don't see where you responded to the up side down mirror flap issue. Andys We do have a clearance issue that would require moving the position of the mirror up to accommodate. We will be producing all visors as shown with the exception of the one that has been specified. As it gets more difficult with more options, and more opportunity to have problems any further requests for the flap on the opposite side will cost the same price as these were when we did the last group buy. $125 per set. When you say "mirror flap orientation" on the site, do you mean left or right or top or bottom flap? |
jrrhdmust |
Mar 14 2014, 09:19 AM
Senior Member Group: Members Posts: 1,402 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None |
I am in for a set with clips.
Thanks, John |
andys |
Mar 14 2014, 09:39 AM
Mark, I don't see where you responded to the up side down mirror flap issue. Andys We do have a clearance issue that would require moving the position of the mirror up to accommodate. We will be producing all visors as shown with the exception of the one that has been specified. As it gets more difficult with more options, and more opportunity to have problems any further requests for the flap on the opposite side will cost the same price as these were when we did the last group buy. $125 per set. Mark, In an ealier post, you responded "I'll check with my guy to see if there are any clearance issues, but I don't see it as a problem." So your guy says there's a clearance issue, and you will not offer the mirror flap oriented in the correct (factory) orientation in this group buy? Just want to be sure I understand correctly. Also, does the "naked" version cost less? Thanks, Andys |
Mar 15 2014, 04:14 PM
done now to find the cores If Mikey can make it work with two left side cores, I've got you covered. I can make them as a left and right, but the screws will be opposite. I can flip one over, but the clamp is set up so it can only be used one way. If you don't mind screws on opposite sides (one up and one down) Yes it can be done. Hope this helps. Looks like this can be fixed by switching the orientation of the small threaded clip. Makes sense to produce one frame and use hardware to determine the proper orientation. Attached image(s) |
aharder |
Mar 15 2014, 05:53 PM
Advanced Member Group: Members Posts: 4,373 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
NFBrown |
Mar 15 2014, 06:15 PM
Newbie Group: Members Posts: 34 Joined: 27-February 13 From: Boise, Idaho Member No.: 15,587 Region Association: Pacific Northwest |
What are cores worth? I think I have one extra, don't know which side without digging it out.
I'll be printing my invoice as soon as I check the condition of my attachment brackets. Nick |
mzalanka |
Mar 16 2014, 06:39 PM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
In for +1 with the clips.
SKL1 |
Mar 16 2014, 07:36 PM
Sent 'em out this afternoon, should be there on Wednesday... invoice and payment enclosed... thanks !
bandjoey |
Mar 16 2014, 08:46 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I'm short 3 of the screw hold down clips (as pictured above). Mine were so rusted up there not usable. Any suggestions on getting these clips or another way to add a speed nut? (IMG:style_emoticons/default/confused24.gif)
Porcharu |
Mar 16 2014, 11:01 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
Can I get them without the mirror??
Mikey914 |
Mar 16 2014, 11:53 PM
Can I get them without the mirror?? Yes, You will need to check naked, and note you do want the pocket if you do. I am tryig to round up some cores, but have not seen any come through yet. so I can't say if I will have any until I see them on my doorstep. SO far Recieved in Invoices 3678 3675 3672 3713 3689 3671 ---- 3696 3688 3679 Tomorrow we should have enough to get started. |
Mikey914 |
Mar 17 2014, 12:06 AM
Mark, I don't see where you responded to the up side down mirror flap issue. Andys We do have a clearance issue that would require moving the position of the mirror up to accommodate. We will be producing all visors as shown with the exception of the one that has been specified. As it gets more difficult with more options, and more opportunity to have problems any further requests for the flap on the opposite side will cost the same price as these were when we did the last group buy. $125 per set. Mark, In an ealier post, you responded "I'll check with my guy to see if there are any clearance issues, but I don't see it as a problem." So your guy says there's a clearance issue, and you will not offer the mirror flap oriented in the correct (factory) orientation in this group buy? Just want to be sure I understand correctly. Also, does the "naked" version cost less? Thanks, Andys Andys, We are offering a GB on the format we have produced and have templates for. We are doing so at a price $21 less that the last GB. We can move the mirror up slightly to make the flap on the opposite side as requested, it just costs us more to have more options. It has to do with the way we make them. These are not idential to factory, but are a good alternative. No the naked does not cost less, as we are giving you the buy at the price of the naked ones on the old GB. On the last GBthe majority of the guys want them with all the options, so we set up to make them in mass at the lower price. We have made all the parts, the question is do you want them attached to yours? Were just trying to get you a good product at the best possible price for the majority. |
Mikey914 |
Mar 17 2014, 12:12 AM
I'm short 3 of the screw hold down clips (as pictured above). Mine were so rusted up there not usable. Any suggestions on getting these clips or another way to add a speed nut? (IMG:style_emoticons/default/confused24.gif) I'll look into this as I have a set here that I just noticed was missing them. -mark |
bulitt |
Mar 17 2014, 05:13 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Can I get them without the mirror?? Yes, You will need to check naked, and note you do want the pocket if you do. I am tryig to round up some cores, but have not seen any come through yet. so I can't say if I will have any until I see them on my doorstep. SO far Recieved in Invoices 3678 3675 3672 3713 3689 3671 ---- 3696 3688 3679 Tomorrow we should have enough to get started. Think you are overlooking some invoices? I purchased online and my number is 3702. Walter Olin appears to have 3701 |
bandjoey |
Mar 17 2014, 09:02 AM
Mine is 3683
Does anyone know what the name of the speed nut clip is??? I'm searching but not seeing anything online like this. Stopping by Ace Hardware later today, too. Thanks! Mike...unless you say otherwise, I'm holding off shipping the cores for a couple of days in search of the speed nuts. Bill Attached image(s) |
Lo-Fi Version | Time is now: 27th April 2024 - 02:05 PM |
