| Mikey914 |
Mar 6 2014, 02:14 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
If you've done a bare metal restoration, you may well be familiar with this part. probably 80% of all the cars out there have the factory original offset isolators. Most have deteriorated and cracked if not sheared.
Mine actually split in 2. These are a no brainier to replace if you are doing a complete restoration. The straight ones available at ace will not cut it here. Shown in the instruction page of the maintenance manual is the only reference to the nut that holds the assembly in. ***The easy way to get at the nut is to remove the speedometer*** I will have these in about 2 weeks with some other items so you will be able to combine for shipping. Attached thumbnail(s) Attached image(s)
| Mikey914 |
Mar 6 2014, 02:15 AM
The cracked OEM is shown below
| GaroldShaffer |
Mar 6 2014, 07:12 AM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,648 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
| Mikey914 |
Mar 6 2014, 12:23 PM
I really thought there would be more interest for these. That's ok, I can go long on them, but it means the price after GB will be more.
| sbsix |
Mar 6 2014, 01:51 PM
only the lead dog enjoys a change in scenery... ![]() ![]() Group: Members Posts: 462 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California
I really thought there would be more interest for these. That's ok, I can go long on them, but it means the price after GB will be more. Mark, I think you are ahead of the curve on this one because most of us haven't given this part a thought, ever. But now that you are thinking about producing a run I need to look at my car and probably get in line to buy a set. |
| Mikey914 |
Mar 6 2014, 02:15 PM
I figured with the number of full restorations this was a good part to make.
| sbsix |
Mar 6 2014, 03:31 PM
| JmuRiz |
Mar 6 2014, 03:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,633 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Interesting, never even thought about that part.
| Mike Bellis |
Mar 6 2014, 04:26 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I want some. (IMG:style_emoticons/default/smile.gif)
| JamesM |
Mar 6 2014, 05:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,236 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
as always, put me down for 3 cars worth
| bdstone914 |
Mar 6 2014, 05:29 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Mike,
This is definitely a needed item as I have never seen a good one on all the parts cars I have seen. Many members are probably not aware of it. Is your going to be made better than the OE? It seems to be a weak design. The 911 wiper assemblies use a thick web like a muffler hanger. Bruce |
| JFJ914 |
Mar 6 2014, 07:08 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
I need one.
| Mikey914 |
Mar 6 2014, 07:50 PM
Mike, This is definitely a needed item as I have never seen a good one on all the parts cars I have seen. Many members are probably not aware of it. Is your going to be made better than the OE? It seems to be a weak design. The 911 wiper assemblies use a thick web like a muffler hanger. Bruce Mine is just like OE with new rubber. I figure it should be good for another 30 years+. |
| Mikey914 |
Mar 6 2014, 07:52 PM
| mrbubblehead |
Mar 6 2014, 08:18 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
mark, put me down for 4.
| cconcepcion |
Mar 6 2014, 08:23 PM
Member ![]() ![]() Group: Members Posts: 51 Joined: 5-January 06 From: Peoria,Az Member No.: 5,370 |
I need a pair asap…
Thanks, Cesar |
| X911IC |
Mar 6 2014, 09:00 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 17-June 13 From: California Member No.: 16,026 Region Association: Southern California |
Mark, are there one or two per car? Count me in for whichever is needed. Neil
| walterolin |
Mar 6 2014, 10:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
I'll take two.
| FL000 |
Mar 6 2014, 10:17 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California
I'll take one. Mine broke when I removed it, and I did order a couple that looked compatible from McMaster...but would rather go with a sure thing.
Thanks |
| Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
One per car.
I'll probably take a dozen. MUCH needed part. Even if you're not doing a full resto. As mentioned by Bruce, almost "all" are cracked by now. This piece stabilizes the wiper assembly which will help ensure your bushings don't get wallowed out as the assembly oscillates on the wiper shafts. Plus, how many people out there yanked all of the wires off the motor, nuts off the shafts then yanked on the assembly to get it out, only to find this piece split in two by the massacre? I'll go out on a limb and say, if you own a 914, you probably need one of these by now. |
Lo-Fi Version | Time is now: 9th June 2026 - 05:37 PM |
