Original rear shocks on '74 teener?, Rear shocks were Boge originally? |
carreraguy |
Mar 11 2014, 04:15 PM
It's not your dad's 914! Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California |
Hi all,
After running my 914aru for a number of years and now realizing my front shocks are bottomed out, I'm looking to revise the suspension to make it a little softer all around for my old butt. I know the fronts were originally Boge so I'll go that route; I'm guessing the rears were Boge also. Can anyone confirm this? Thanks, Tom |
Johny Blackstain |
Mar 11 2014, 05:27 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Generally Boge was the most common shock absorber for the 914 & they are usually black. Old Bilsteins were green & now they are yellow. Konis were redddish orange. If you pull the old shock out & clean it up it should be marked as to what it is. Hope that helps.
bdstone914 |
Mar 19 2014, 08:06 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Generally Boge was the most common shock absorber for the 914 & they are usually black. Old Bilsteins were green & now they are yellow. Konis were redddish orange. If you pull the old shock out & clean it up it should be marked as to what it is. Hope that helps. All of the original Boge shocks I have seen were grey. They have a unique lower perch that locates one three raised bumps. I have seen replacement Boge in Orange-red much like the color of Koni shocks. |
tod914 |
Mar 25 2014, 08:08 PM
Here you go, in case you want to paint them the oem color.
http://www.914world.com/bbs2/index.php?sho...553&hl=grey |
Lo-Fi Version | Time is now: 5th May 2024 - 12:22 AM |
