rmdinmd |
Member ![]() ![]() Group: Members Posts: 489 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
as the description says where can you get them and what do you use. you buy the oil screen filter kit and it comes with the two gaskets and one crush ring not two.
for now I am using a neoprene washer as a gasket, I think I have read where some guys use copper washers. is that correct and if so size and where to get would be very helpful. I am trying hard to do things right to the point I bought a torque wrench that goes down to 5 lbs so I could avoid over torqueing the strainer nut. thanks in advance Rick |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
as the description says where can you get them and what do you use. you buy the oil screen filter kit and it comes with the two gaskets and one crush ring not two. for now I am using a neoprene washer as a gasket, I think I have read where some guys use copper washers. is that correct and if so size and where to get would be very helpful. I am trying hard to do things right to the point I bought a torque wrench that goes down to 5 lbs so I could avoid over torqueing the strainer nut. thanks in advance Rick Far in the past, there were 2 sealing rings per kit. Cheapness rules, and they've removed one of them. Mose folks don't remove the drain plug, I think, so the second ring isn't really necessary. I suppose I could contact my gasket guy and ask him if he has them in bulk. That's predicated, of course, demand for them. I have a $100 minimum order .............. The Cap'n |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
contact rotary914 here in the vendors forum.
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
as the description says where can you get them and what do you use. you buy the oil screen filter kit and it comes with the two gaskets and one crush ring not two. for now I am using a neoprene washer as a gasket, I think I have read where some guys use copper washers. is that correct and if so size and where to get would be very helpful. I am trying hard to do things right to the point I bought a torque wrench that goes down to 5 lbs so I could avoid over torqueing the strainer nut. thanks in advance Rick I don't bother to change the copper gasket (what's left) on my drain plug. I just put it back on. On the oil sump, I used the gaskets and copper washer as you describe. |
Shindog1961 |
Member ![]() ![]() Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region ![]() |
Cap'n Krusty |
The price is good, but they charge you freight (USPS Priority Mail) and the price break is at 50. If I bought a hundred for $30, add in the postage (about 8 bucks), and the outgoing postage to forum members, they'd be 88 cents apiece. Of course, that would go down for orders for more than one piece. If I can get enough orders for 10 per order, I can do this for $6.50 for 10, delivered. Sure, I make a little money, but it's not like it covers the hassle or anything.
The Cap'n |
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
Hey Cap'n - can you get the sump gaskets & seal and offer a complete kit for the lazy sob's like me? I would go for 10 kits.
Cap'n Krusty |
Shipping 10 kits brings on more shipping costs. 4 bucks a set, plus whatever the postage is. That's maybe 43 bucks, delivered, including a buck for Mr. Paypal? The gaskets are the nice German ones, not those POS thin Sabo gaskets.
The Cap'n |
rmdinmd |
somehow I suspect I am not the only one that has run into this. Captn, if you decide to do that I would be in for 10 of them; otherwise I'll bite the bullet and get 50 myselfe and never need to buy another one again. (IMG:style_emoticons/default/blink.gif)
Intubator |
Newbie ![]() Group: Members Posts: 18 Joined: 12-January 14 From: Maryland Member No.: 16,878 Region Association: North East States ![]() |
These are available from AA at a $1.00 each the size is 22x27mm, of course you have the minimum shipping issue... You might be able to get a bunch at a place like this for the same shipping or less and probably less per piece in a larger quantity: http://www.mcmaster.com/# Sometimes I'll do a Google search with just the part # to see what options pop up too. The Porsche part # is 90012301130
Intubator |
Here's the actual sealing ring in the McMaster Catalog. Pack of 10 for $9 and change. http://www.mcmaster.com/#97725a950/=r50m59
Cap'n Krusty |
Here's the actual sealing ring in the McMaster Catalog. Pack of 10 for $9 and change. http://www.mcmaster.com/#97725a950/=r50m59 Nice try. Right diameter. Wrong part. The Cap'n |
Intubator |
Here's the actual sealing ring in the McMaster Catalog. Pack of 10 for $9 and change. http://www.mcmaster.com/#97725a950/=r50m59 Nice try. Right diameter. Wrong part. The Cap'n OK, how so? |
michael7810 |
I'll do 10 of the Cap'n' kits for 43 bucks. Let us know if it's a go and thanks for helping the community.
rmdinmd |
Found them here. http://www.airheadparts.com/vintage-vw-par...r-12x18-n138052 shipping cost is a little crazy but just buy a bunch. |
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
I'm game for a group buy and I'm good for 20. If you buy 250 the shipping is free from Belmetric.
David |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Hey John, I'd take 5 of those kits if you do a run. (IMG:style_emoticons/default/piratenanner.gif)
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
Anybody else just do the drain plug/washer and oil filter without the sump thingy? I've never cleaned out that strainer thing. Or replaced the gasket. It's big and scary looking, like it won't seal again. Am I going to air-cooled hell?? Save me, Cap'n!
Paul |
Cap'n Krusty |
Well, I lost track of this one! Sorry. My source is out right now, but I have another, I think. I'll get on this Monday and see what I can do.
I do the screen every time. There's apt to be glop and other nasty stuff on there, stuff you want to monitor. The Cap'n |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Just a customer. Al Zim has the original that's in the screen kit to sell individually.
Allzim.com |
Lo-Fi Version | Time is now: 11th July 2025 - 12:03 AM |
