> oil change; crush washer found, what do you use for the sealing ring, crush washer.
rmdinmd
post Mar 16 2014, 02:22 PM
as the description says where can you get them and what do you use. you buy the oil screen filter kit and it comes with the two gaskets and one crush ring not two.
for now I am using a neoprene washer as a gasket, I think I have read where some guys use copper washers. is that correct and if so size and where to get would be very helpful. I am trying hard to do things right to the point I bought a torque wrench that goes down to 5 lbs so I could avoid over torqueing the strainer nut.
thanks in advance
Rick
2 Pages V < 1 2
Replies(20 - 25)
rmital
post May 10 2014, 10:37 AM
Post #21
Northeast optimist
QUOTE(bandjoey @ May 10 2014, 12:11 PM) *
Just a customer. Al Zim has the original that's in the screen kit to sell individually.
Allzim.com
....those don't look right....have you purchased them?
reharvey
post May 10 2014, 11:54 AM
Post #22
http://www.ebay.com/itm/12mm-ID-COPPER-CRU...S-/390285719861
These are not crush washers but they are exactly the right size and I've never had one leak. Been using them for years without a problem.
bandjoey
post May 10 2014, 03:51 PM
Post #23
bandjoey
Havent looked at their www. On my phone. What I buy across the counter is exactly what's in the strainer bag. Zims that is. Call em on Monday for a chat. Nice people.
euro911
post May 10 2014, 04:17 PM
Post #24
I never could understand why when one purchases something like 10 little crush washers, why the vendor just doesn't mail them in a small padded envelope USPS First Class Mail for about $2.00, instead of a box loaded with packing material for $9.95 (IMG:style_emoticons/default/screwy.gif)
Actually, if you include a paper sheet of printed instruction with them, you could mail it via USPS Media Mail for about a buck (IMG:style_emoticons/default/shades.gif)
Cap'n Krusty
post May 10 2014, 06:34 PM
Post #25
Cap'n Krusty
QUOTE(reharvey @ May 10 2014, 10:54 AM) *
Might work OK for the drain plug, but 11ft/lbs of torque isn't gonna do diddly to make that washer seal on the sump cover.
The Cap'n
bandjoey
post May 10 2014, 07:10 PM
Post #26
bandjoey
QUOTE(Cap'n Krusty @ May 10 2014, 07:34 PM) *
These are not crush washers but they are exactly the right size and I've never had one leak. Been using them for years without a problem.ynes shows 9.4 LSD on the sump. Is
Ha
The Cap'n
.? Cap'n. Haynes says 9.4 lbs on the sump cover. Is it better to go to 11 or is it another Haynes mistake? Thanks
2 Pages V < 1 2
- Lo-Fi Version Time is now: 11th July 2025 - 04:18 AM
