904 Mainshaft, ...did I just stumble on one? |
yeahmag |
Mar 17 2014, 03:50 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
tscrihfield |
Mar 17 2014, 04:02 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Yes, that appears to be a 904 main shaft.
tscrihfield |
Mar 17 2014, 04:03 PM
But it looks to be a little rough!
yeahmag |
Mar 17 2014, 04:07 PM
It's quite dirty. Other than that it looks passable to me. I'd have to have Dr. Evil to look at it to know for sure.
Qarl |
Mar 17 2014, 05:12 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
It's quite dirty. Other than that it looks passable to me. I'd have to have Dr. Evil to look at it to know for sure. Looks like the one I had... (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1395097985.1.JPG) |
yeahmag |
Mar 17 2014, 05:53 PM
I'm probably not gonna use this thing as I can't afford to build a box of the caliber.
Cap'n Krusty |
Mar 17 2014, 06:18 PM
I was wondering where I left that thing .........................
The Cap'n |
Woody |
Mar 17 2014, 06:51 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I'll give you $50 to send it to me so I can verify. (IMG:style_emoticons/default/happy11.gif)
toolguy |
Mar 17 2014, 06:58 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
put it on a lathe a turn slowly and see if it has any runout. . since these were used on 'performance' motors, I've seen more than a few that have bow in the gear stack area. . just a smidge will make the gears mesh too tight on one side and loose on the other. . If it's straight you hit the jackpot, plus see what the gears were in the transmission it came out of. . you might have a nice setup ready to go. .
boxsterfan |
Mar 17 2014, 09:41 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
How much do these 904 mainshafts go for?
jaxdream |
Mar 17 2014, 09:45 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
About a 915 ???!!!! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif)
Jack |
Qarl |
Mar 17 2014, 10:33 PM
QUOTE How much do these 904 mainshafts go for? I think I sold my NOS 3 years ago for $1350 |
Qarl |
Mar 17 2014, 10:41 PM
QUOTE How much do these 904 mainshafts go for? I think I sold my NOS 3 years ago for $1350 http://www.ebay.com/itm/PORSCHE-COMPETITIO...=item3cdb7b6429 |
yeahmag |
Mar 18 2014, 10:48 AM
So, I'll be eyeballing this thing on the lathe in the next few days to see how the runout is. After that it goes up for sale. Daddy needs a new set of tires... ;-)
Katmanken |
Mar 18 2014, 08:40 PM
Straightening a shaft ain't no big thing. I used to get large quantities of precision diameter steel shafts (centerless ground) and straight to half a thousandths.
Watched the ladies do it too. They slapped a shaft on a fixture, spun the shaft while looking at the dial indicator and whammed the shaft with the press when the high side was under the press. Some fixtures had 1 press at the center, and some 2 presses at the 1/3 and the 2/3 points on the shaft. They could straighten a shaft in under 30 seconds. Wham, wham, wham..... Attached image(s) |
Dr Evil |
Mar 18 2014, 09:25 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Dang, wish I found a 904 shaft in the pile. Shit, I wish I had a pile. West PA is a suck pocket for cores and 914 stuff.
stownsen914 |
Mar 19 2014, 10:44 AM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Got any 2nd gearsets to go with that thing? They're valuable too. I got a couple sets in a lot of 901 gearsets I bought a few years ago. We get lucky every once in a while ...
ldsgeek |
Mar 19 2014, 07:32 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Straightening a shaft ain't no big thing. I used to get large quantities of precision diameter steel shafts (centerless ground) and straight to half a thousandths. Watched the ladies do it too. They slapped a shaft on a fixture, spun the shaft while looking at the dial indicator and whammed the shaft with the press when the high side was under the press. Some fixtures had 1 press at the center, and some 2 presses at the 1/3 and the 2/3 points on the shaft. They could straighen a shaft in under 30 seconds. Wham, wham, wham..... They straighten gun barrels the same way, only they don't use the dial indicator. They look through the bore to find a shadow and use that to figure out where to straighten. |
yeahmag |
Apr 14 2014, 08:07 PM
She's straight! Over the entire length we measured no more than .0015"
yeahmag |
Apr 14 2014, 08:09 PM
We measured in 5 spots along the shaft and all look great. Gave the journals a bit of a polish and put her away.
Lo-Fi Version | Time is now: 9th June 2024 - 11:59 PM |
