yeahmag
Mar 17 2014, 03:50 PM
Might this be the elusive 904 mainshaft? i just picked up about 7 901 cores and this was in one of the boxes of random parts.
Click to view attachment Click to view attachment
tscrihfield
Mar 17 2014, 04:02 PM
Yes, that appears to be a 904 main shaft.
tscrihfield
Mar 17 2014, 04:03 PM
But it looks to be a little rough!
yeahmag
Mar 17 2014, 04:07 PM
It's quite dirty. Other than that it looks passable to me. I'd have to have Dr. Evil to look at it to know for sure.
Qarl
Mar 17 2014, 05:12 PM
QUOTE(yeahmag @ Mar 17 2014, 06:07 PM)
Looks like the one I had...
yeahmag
Mar 17 2014, 05:53 PM
I'm probably not gonna use this thing as I can't afford to build a box of the caliber.
Cap'n Krusty
Mar 17 2014, 06:18 PM
I was wondering where I left that thing .........................
The Cap'n
Woody
Mar 17 2014, 06:51 PM
I'll give you $50 to send it to me so I can verify.
toolguy
Mar 17 2014, 06:58 PM
put it on a lathe a turn slowly and see if it has any runout. . since these were used on 'performance' motors, I've seen more than a few that have bow in the gear stack area. . just a smidge will make the gears mesh too tight on one side and loose on the other. . If it's straight you hit the jackpot, plus see what the gears were in the transmission it came out of. . you might have a nice setup ready to go. .
boxsterfan
Mar 17 2014, 09:41 PM
How much do these 904 mainshafts go for?
jaxdream
Mar 17 2014, 09:45 PM
Qarl
Mar 17 2014, 10:33 PM
I think I sold my NOS 3 years ago for $1350
Qarl
Mar 17 2014, 10:41 PM
QUOTE(Qarl @ Mar 18 2014, 12:33 AM)
http://www.ebay.com/itm/PORSCHE-COMPETITIO...=item3cdb7b6429
yeahmag
Mar 18 2014, 10:48 AM
So, I'll be eyeballing this thing on the lathe in the next few days to see how the runout is. After that it goes up for sale. Daddy needs a new set of tires... ;-)
Katmanken
Mar 18 2014, 08:40 PM
Straightening a shaft ain't no big thing. I used to get large quantities of precision diameter steel shafts (centerless ground) and straight to half a thousandths.
Watched the ladies do it too. They slapped a shaft on a fixture, spun the shaft while looking at the dial indicator and whammed the shaft with the press when the high side was under the press.
Some fixtures had 1 press at the center, and some 2 presses at the 1/3 and the 2/3 points on the shaft. They could straighten a shaft in under 30 seconds. Wham, wham, wham.....
Dr Evil
Mar 18 2014, 09:25 PM
Dang, wish I found a 904 shaft in the pile. Shit, I wish I had a pile. West PA is a suck pocket for cores and 914 stuff.
stownsen914
Mar 19 2014, 10:44 AM
Got any 2nd gearsets to go with that thing? They're valuable too. I got a couple sets in a lot of 901 gearsets I bought a few years ago. We get lucky every once in a while ...
ldsgeek
Mar 19 2014, 07:32 PM
QUOTE(Katmanken @ Mar 18 2014, 06:40 PM)
Some fixtures had 1 press at the center, and some 2 presses at the 1/3 and the 2/3 points on the shaft. They could straighen a shaft in under 30 seconds. Wham, wham, wham.....
They straighten gun barrels the same way, only they don't use the dial indicator. They look through the bore to find a shadow and use that to figure out where to straighten.
yeahmag
Apr 14 2014, 08:07 PM
She's straight! Over the entire length we measured no more than .0015"
yeahmag
Apr 14 2014, 08:09 PM
We measured in 5 spots along the shaft and all look great. Gave the journals a bit of a polish and put her away.
r_towle
Apr 14 2014, 08:17 PM
spray wd40 all over it before you put it away.
Good for keeping surface rust from forming.
rich
Cap'n Krusty
Apr 14 2014, 10:02 PM
Better yet, use LPS3, it's made for that purpose. -1 and -2 would be good, too. WD40 is a second rate product for any use it's put to. If there's already some corrosion, use Evaporust. It's a truly amazing product, even if they do sell it at HF. It removes rust and "pickles" the surfaces so they don't rust again.
The Cap'n
bdstone914
Apr 14 2014, 11:06 PM
QUOTE(Cap'n Krusty @ Apr 14 2014, 09:02 PM)
The Cap'n
Agreed on the Evaporust. You can buy it a O'Reillys for $22 per gallon which is less then HF sells it for.
http://www.oreillyauto.com/site/c/search/R...ap?keyword=rust
Dr Evil
Apr 15 2014, 03:28 PM
Man, these things used to be rare and expensive, but a quick search on Ebay shows 3, 2 under $1200 and one for about $900, all BIN. I just bought one to sell.....I thought I got a better deal
