Head Installation, Sealant Under Washers? |
Allan |
Jan 9 2005, 04:00 PM
Ready to install the nos. 3 & 4 cylinder head and was wondering about putting a sealant of some type under the washers and nuts that sit inside the head. This seems like a spot where leaks could happen. Any words of wisdom?
Allan |
Jan 9 2005, 04:38 PM
Rhodes71/914 |
Jan 9 2005, 04:48 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I'll give you my limited knowledge and put a disclaimer that I am not a type 4 pro but have had a few apart and back together.(not wanting to give bad advice)
That being said I have never seen or heard of sealant under those washers. There is some oil in the rocker arm area but I think the nut and washer do a good enough job. |
McMark |
Jan 9 2005, 04:53 PM
nah. liquid teflon if ya want.
newdeal2 |
Jan 9 2005, 04:59 PM
Unregistered |
None required. But do consider sealant at the pushrod tubes, I used Hylomar on both ends around the seals. Dry as a bone so far (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Allan |
Jan 9 2005, 05:12 PM
Thanks guys. I think a little bit of teflon under the washers. What about permatex 3H on the push rod tube seals. Every thing I've seen so far says just to use a little oil.
newdeal2 |
Jan 9 2005, 05:17 PM
Unregistered |
I have heard of using Permatex but in my [humble] opinion you need to keep things soft due to the expansion/contraction and I think Permatex will tend to harden too much. I went with the Hylomar. Experts feel free to chime in. |
Rhodes71/914 |
Jan 9 2005, 05:21 PM
Seams like it's split on whether to use any sealant on the PR tube seals. I just went with a little oil. Won't know about leaks for awhile, gotta do some other stuff before I can run it.
newdeal2 |
Jan 9 2005, 05:23 PM
Unregistered |
I have about 4-6 hours of runnng time on my engine going thru the tuning process of the new rebuild and used Hylomar. Still no signs of a leak.
Jan 9 2005, 07:43 PM
Custom Member Group: Members Posts: 24,567 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
No on the washers.
Yes most definetely on the pushrod tube seals. they leak by design. It is an easy fix if you choose to wait, you can fix it in the car. Pelican has a great article on it. Rich |
Allan |
Jan 9 2005, 07:50 PM
It's too late. I put just a little under the washers (Not even enough to push out under torque). We'll see I guess. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Joe Ricard |
Jan 9 2005, 08:01 PM
You'll be fine with what you got. ????? Did you only do one head? Normally I do both heads at the same time torquing each down in the steps outlined in several technical manuals. |
Allan |
Jan 9 2005, 08:10 PM
I only did the 3 & 4 side. I know that Tom Wilson's book says to do them together but then Jake's video shows them as seperate assemblies. I'm working on the 1 & 2 now.
Jake Raby |
Jan 10 2005, 07:31 AM
Liquid teflon cut a bit with some mineral spirits works well..
The best thing is Curil T |
Lo-Fi Version | Time is now: 28th April 2024 - 03:13 PM |
