Push Rod Tube Seals, Confusing Colors |
Allan |
Jan 9 2005, 07:05 PM
I was told to throw away the seals for the push rods that come in the gasket set because they are junk. I ordered a set of Viton seals about 6 months ago from AA. They are black. I thought the Vitons were a brownish color, but then again, Jakes video shows them as green. Which way do I go?
elwood-914 |
Jan 9 2005, 07:10 PM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
I just installed Viton seals and they were green.
Allan |
Jan 9 2005, 07:48 PM
That's what I mean. I ordered Viton and got 8 seals all black. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) WTF? I'm not going to put them in until I know for sure.
eric914 |
Jan 9 2005, 07:55 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
The following link has a photo and list of most of the seals and gaskets required for a rebuild. It has the part number for the brown Viton push rod tube seals as
Push rod tube o-rings 021 109 345VK 16 piece $14.95 Brown Viton http://www.ratwell.com/technical/GasketSet.html Hope this helps. |
Allan |
Jan 9 2005, 09:45 PM
I bought the same exact kit but was told to ditch the push rod tube seals. Why does it have to be this way????
brp914 |
Jan 9 2005, 10:46 PM
Unregistered |
I've had bad luck with the seals from the gasket kit, but the last time I tried them >10 yrs ago. They leaked within a matter of months. I've built a couple engines since then. Last time was 2 years ago. I got the set fron Perf. Prod. They are brown (inner and outter) $20. No problems. I think brown means they are viton. I've also bought them from the Porsche dealer which were a shiney red which also were good. I believe those were silicone.
Natedog |
Jan 10 2005, 03:05 PM
Member Group: Members Posts: 107 Joined: 20-October 03 From: Fort Collins, CO Member No.: 1,265 |
[QUOTE]I was told to throw away the seals for the push rods that come in the gasket set because they are junk.
Allan - did you order your seal kit from Pelican? I just finished rebuilding and installing my 1973 2.0 engine using that seal kit. Half of the PR seals were green and half - ??? I can't remember. Are you other guys suggesting that those PR seals in the Pelican kit will fail? Cheers, Nate |
ClayPerrine |
Jan 10 2005, 03:09 PM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have bought green, black and brown viton seals over the years. They all work about the same. If you were sold viton seals, they should be fine.
Allan |
Jan 10 2005, 05:05 PM
No, I got the kit from GPR but it was a Victor-Reinz kit so it will have the same parts in it. Has both green and black push rod tube seals. Just to make sure, I ordered a set of brown vitons from GPR today. $1.20 ea. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Allan |
Jan 10 2005, 05:08 PM
Set comes with green and black seals. If it's a Victor-Reinz kit it has the same stuff in it no matter where you buy it. I got mine from GPR. Went ahead and ordered a set of brown vitons today from GPR. |
Lo-Fi Version | Time is now: 4th May 2024 - 09:48 PM |
