Headlight hydraulics |
dw914six |
Mar 20 2014, 07:38 PM
Member Group: Members Posts: 131 Joined: 18-January 14 From: Houston Member No.: 16,902 Region Association: Southwest Region |
I just drove my 914/6 car home after a transmission rebuild by the good Dr. Evil. (IMG:style_emoticons/default/biggrin.gif)
Now,of course, new issues to tackle. (IMG:style_emoticons/default/mad.gif) My passenger headlight will not go go down after I turn the car off. I had to manually bring it down by turning the top of the motor. Any ideas what the issue is? (IMG:style_emoticons/default/dry.gif) Thanks for any ideas. |
GeorgeRud |
Mar 20 2014, 07:45 PM
Check the fuse and the relay?
dw914six |
Mar 20 2014, 08:02 PM
Check the fuse and the relay? Can't be that...it would be too easy. (IMG:style_emoticons/default/screwy.gif) I will check it out though. I was thinking motor failure or something more exasperating. |
Mar 20 2014, 09:28 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Headlight hydraulics The oil probably drained out of the headlight hydraulics ... (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
Mar 20 2014, 09:34 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check your blinker fluid too (IMG:style_emoticons/default/biggrin.gif)
bdstone914 |
Mar 20 2014, 10:10 PM
Check the fuse and the relay? Can't be that...it would be too easy. (IMG:style_emoticons/default/screwy.gif) I will check it out though. I was thinking motor failure or something more exasperating. Not likely to be the motor if it goes up. Check the relay under the linkage cover and the connections inside the plastic blocks. There are three wires. Ground, power up and power down. You can manually apply power. Keep you hands away from the linkage arms so you don't get short fingers. |
dw914six |
Mar 20 2014, 10:16 PM
Check the fuse and the relay? Can't be that...it would be too easy. (IMG:style_emoticons/default/screwy.gif) I will check it out though. I was thinking motor failure or something more exasperating. Not likely to be the motor if it goes up. Check the relay under the linkage cover and the connections inside the plastic blocks. There are three wires. Ground, power up and power down. You can manually apply power. Keep you hands away from the linkage arms so you don't get short fingers. (IMG:style_emoticons/default/blink.gif) ouch! I did that once on a table saw. Bad way to learn a lesson believe me. 9 hour surgery and a few years of rehab and I can play golf again. Bit not the guitar. Thanks guys for the advice. I will try everything mentioned. (IMG:style_emoticons/default/aktion035.gif) |
toolguy |
Mar 20 2014, 10:33 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
the same lead goes to both motors. . If one goes down, the headlight switch is OK. and the lead from the switch to the left motor is good. . . the lead from the headlight switch goes to the drivers side motor and halftaps off over to the passenger side motor. Best place to start is to swap the relays side to side and see where the trouble goes. . if no change, trace continuity, or the motor itself. . the motor gearbox has contacts inside it to control stop position and direction. .
Green/ Blk is the down lead. . it should have 12v on it when the headlights are to go down. |
dw914six |
Mar 20 2014, 10:44 PM
the same lead goes to both motors. . If one goes down, the headlight switch is OK. and the lead from the switch to the left motor is good. . . the lead from the headlight switch goes to the drivers side motor and halftaps off over to the passenger side motor. Best place to start is to swap the relays side to side and see where the trouble goes. . if no change, trace continuity, or the motor itself. . the motor gearbox has contacts inside it to control stop position and direction. . Green/ Blk is the down lead. . it should have 12v on it when the headlights are to go down. (IMG:style_emoticons/default/drooley.gif) amazing depth of knowledge you folks have. The advice is appreciated. |
Mar 21 2014, 07:15 AM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
the same lead goes to both motors. . If one goes down, the headlight switch is OK. and the lead from the switch to the left motor is good. . . the lead from the headlight switch goes to the drivers side motor and halftaps off over to the passenger side motor. Best place to start is to swap the relays side to side and see where the trouble goes. . if no change, trace continuity, or the motor itself. . the motor gearbox has contacts inside it to control stop position and direction. . Green/ Blk is the down lead. . it should have 12v on it when the headlights are to go down. small hijack - my lights go up but not down and now they will not turn on. before that, just the high beam would turn on. what should I be looking for? thanks |
toolguy |
Mar 21 2014, 07:30 PM
lose fuses
Mar 21 2014, 07:58 PM
ConeDodger |
Mar 21 2014, 08:07 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Headlight hydraulics The oil probably drained out of the headlight hydraulics ... (IMG:style_emoticons/default/biggrin.gif) Man, I got here late for that... (IMG:style_emoticons/default/av-943.gif) |
dw914six |
Mar 21 2014, 08:16 PM
Headlight hydraulics The oil probably drained out of the headlight hydraulics ... (IMG:style_emoticons/default/biggrin.gif) Man, I got here late for that... (IMG:style_emoticons/default/av-943.gif) Yeah, that and blinker fluid were especially good. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:51 AM |
