> 901 or clutch noise
dw914six
post Mar 20 2014, 08:36 PM
(IMG:style_emoticons/default/evilgrin.gif) yep, I'm back. Issue #2 with my 914/6. I just installed the 901, just rebuilt by the very excellent Dr. Evil. Drove it home and the gears work great. However, I am getting a small "whirring" noise while driving, that goes away completely when the clutch is engaged.
Any ideas on the cause of the noise? M (IMG:style_emoticons/default/confused24.gif)
Thanks World.
wndsnd
post Mar 20 2014, 09:01 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Did you replace the throw out bearing?
dw914six
post Mar 20 2014, 10:23 PM
QUOTE(wndsnd @ Mar 20 2014, 07:01 PM) *
If it is part of the gear stack, then it was either ok or replaced. Mike (Dr. Evil) did the rebuild. We just installed it back in the car. (IMG:style_emoticons/default/w00t.gif)
I am thinking pinion depth is off a bit. Would that make sense to anyone? Would that cause a whirring sound when the car is rolling? Then goes quiet when. I push in the clutch?
I just hate that because it requires dropping the tranny again and draining expensive swepco oil and pulling the stack out. Just a lot of work after all of this already done. (IMG:style_emoticons/default/headbang.gif)
brant
post Mar 20 2014, 10:25 PM
nope...
not part of the gear stack
in the bell housing
a bearing to replace when you service the clutch
dw914six
post Mar 20 2014, 10:39 PM
QUOTE(brant @ Mar 20 2014, 08:25 PM) *
nope...
in the bell housing
Prior to rebuilding the tranny I had the clutch replaced. About 10 miles ago, so it is a fresh install. I will check receipts. Thanks. But there was no noise after the clutch install. (IMG:style_emoticons/default/sunglasses.gif)
bulitt
post Mar 21 2014, 05:07 AM
Achtzylinder
Number 8 in the dia. Make sure when the clutch is not depressed- the bearing is not spinning.
Did you use a synthetic gear oil?
(IMG:http://www.914world.com/bbs2/uploads_offsite/c767504.r4.cf2.rackcdn.com-13632-1395400049.1.gif)
Dr Evil
post Mar 22 2014, 06:42 PM
Send me your transmission!
Yes, I agree that the TOB is the likeliest culprit. (IMG:style_emoticons/default/smile.gif) Lemme know.
Dr Evil
post Mar 22 2014, 06:44 PM
Just to be clear, I did the stack rebuild only so pinion depth was not set by me (IMG:style_emoticons/default/wink.gif)
But, I still think it is the TOB most likely.
dw914six
post Mar 22 2014, 06:59 PM
QUOTE(bulitt @ Mar 21 2014, 03:07 AM) *
Swepco 201 ... No synthetics.
dw914six
post Mar 22 2014, 07:01 PM
QUOTE(Dr Evil @ Mar 22 2014, 04:44 PM) *
Ahhh, that is correct...which is why I was leaning to the pinion depth....if it could be messed up on my end...that is probably what happened. I will drive it a bit to see if it sets in and goes away.
- Lo-Fi Version Time is now: 15th March 2026 - 11:06 AM
