| john77 |
Mar 21 2014, 10:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California
New to 914s and trying to sort through some electrical issues.
My passenger side rear tail light has stopped working. I traced all the wires leading back there from the engine compartment side of the firewall and they're good. I removed and cleaned the ground at the lamp housing. I swapped the bulb into the driver side lamp and it worked fine. I tested the connection inside, where the bulb touches whatever that metal piece is called and it shows no voltage. However, the brake light works fine. Looking at Tech Tips 700, it doesn't list one of the rear light housing terminals as simply 'tail light' - there's ground, turn signal, reverse light, brake light and parking light. And looking at the Haynes manual only the left and right parking lights go directly back to the fuse box. So I'm a little confused about which wire I should be tracing the other side of the firewall. Is the tail light connected to parking light? Fuse 6 keeps popping (although oddly I replaced the fuse tonight, it didn't pop yet the parking lights still aren't working??) so if they are connected, whatever's causing that is my culprit. If not I have no idea where to look next. John |
| Tom |
Mar 22 2014, 04:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Yes, the tail light is connected to the parking light. The side marker light is also included in that circuit, so that may be your problem. Maybe take the right side marker light apart and clean it up.
Tom |
| ripper911 |
Mar 22 2014, 07:42 AM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Some previous owner marked my taillight housings.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1395495763.1.jpg) It's a 74 Hope it helps. |
Lo-Fi Version | Time is now: 16th April 2026 - 11:20 PM |
