> Heat exchanger/muffler question, can I modify this?
Scott S
post Jan 10 2005, 11:26 AM
Small Member
Hi All -
My car has 1.7l stainless heat exchangers thatare in nearly new condition. They were installed by the PO. I really want to continue in the spirit of the GT and install the correct muffler - however the upward bend of the 1.7 exchangers wont allow it. Being that creating this muffler requires cutting holes and welding in new pipes, can I do the same thing on the rear and simply move the flanges up so it fits with the 1.7 exchangers?
Does any company (like triad) make a muffler where I can use my current exchangers, but gives the appearance of the dual outlet GT muffler?
In a perfect world, I would want to use the 2.0 muffler, add the pipes - but cap them off, keeping the factory outlet as well. I saw this on an RSR -looked very mean.
Root_Werks
post Jan 10 2005, 11:38 AM
Village Idiot
If it is the can or banananananana style muffler, you can't easily move the rear flanges as the pipes go inside the can into longer tubes. I bet it could be done, just not easily.
Know anyone that could bend the SSI flanges down, then shorten them to put them back to a stock 2.0 spot and re-weld them? Seems easier? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Dave_Darling
post Jan 10 2005, 04:18 PM
914 Idiot
How about Door Number Three--
Swap the exchangers for a 2.0 set, then use the 2.0 muffler! Fake up a 2.0 muffler hanger, while you're at it. (There are a number of 1.7 folks with 2.0 SSIs, because the 1.7 ones have been out of stock for many years.)
Heck of a lot easier than modifying the SSIs, or re-locating the inlets on the muffler.
--DD
post Jan 10 2005, 04:25 PM
Resident German
QUOTE (Dave_Darling @ Jan 10 2005, 02:18 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
the 2.0L SSI's are still available and you should be able to trade your 1.7 set for a 2.0 set ...
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy
Scott S
post Jan 10 2005, 04:30 PM
Small Member
Yep, thought of that too. Mine exchangers are really clean and I have read so many threads about exhaust stud problems that I just wanted to leave it all be as is. But youre exactly right - that is the way it should be done.... damn.
Thanks!
- Lo-Fi Version Time is now: 11th July 2025 - 02:21 AM
