3 Pages V < 1 2 3
> Valve Adjustment - do it myself or have it done?
stugray
post Apr 23 2014, 07:21 AM
Post #41
Actually the best feeler gauge is the "Go/No-Go" style.
It leaves nothing to "guess" if the feeler is tight enough or not.
I bought a brand new set at my FLAPS and then installed Jakes pushrods, so I dont need feeler gauges anymore....
Cap'n Krusty
post Apr 23 2014, 08:05 AM
Post #42
Cap'n Krusty
QUOTE(wobbletop @ Mar 27 2014, 11:57 AM) *
What about for a 6?
Still a DIY? Link to tips?
You do a 6 the same way. Even easier, because you can actually see the cam lobes.
The Cap'n
VaccaRabite
post Apr 23 2014, 01:01 PM
Post #43
En Garde!
The Krusty way is the best way.
It does not take long. You do not need to remove the heater boxes. You do have to trust what your fingers and feeler gauge are telling you, though.
It's a task that builds self confidence!
Zach
wobbletop
post Apr 24 2014, 08:26 AM
Post #44
QUOTE(Cap'n Krusty @ Apr 23 2014, 10:05 AM) *
What about for a 6?
The Cap'n
Thanks!
Next question is are there preferences for valve cover gaskets? I assume they have to be replaced everytime. Probably as open ended question as what type of oil or brand of tires do you like.
Cap'n Krusty
post Apr 24 2014, 08:36 AM
Post #45
Cap'n Krusty
QUOTE(wobbletop @ Apr 24 2014, 07:26 AM) *
What about for a 6?
The Cap'n
Thanks!
For 4 cylinder cars, I prefer the Elring over the Sabo (which is probably toe only other brand available). I replace them when they're no longer soft, and I glue them to the valve covers with Gasgacinch. Some folks grease the head side, but I've never found that to be particularly necessary.
The Cap'n
wobbletop
post Apr 24 2014, 08:38 AM
Post #46
QUOTE(Cap'n Krusty @ Apr 24 2014, 10:36 AM) *
The Cap'n
And for a six with turbo valve covers...
TheWeatherMan
post Jul 4 2017, 07:15 PM
Post #47
QUOTE(tumamilhem @ Mar 25 2014, 02:17 PM) *
How long would it take an experienced mechanic (anybody here who does it) a valve adjustment on a /4?
it took me roughly 6 hours to go through the whole process, reading up on it, finding TDC, marking the flywheel, then double and triple checking measurements.
Once I was done the car stopped backfiring and had zero hesitation through each gear.
Rand
post Jul 7 2017, 02:32 PM
Post #48
Cross Member
6 hours? Practice more, it shouldn't take 30 minutes start to finish. Interesting seeing so many ancient threads drudged up lately.
TheWeatherMan
post Jul 7 2017, 06:05 PM
Post #49
QUOTE(Rand @ Jul 7 2017, 04:32 PM) *
After figuring out the process and marking the flywheel I could probably do it in about an hour or so
dwell and timing on the car seems to be ok. No mark on the fan for TDC or 27 degree BTDC...need to figure this out
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 7th December 2025 - 05:04 AM
