| AE354803 |
Mar 25 2014, 02:34 PM
Member ![]() ![]() Group: Members Posts: 238 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
I need to clean up some injectors for a daily driver Volvo. I would normally send them out but the car is driven every day and the driver can't/won't drive a manual car so there is nothing for them to use during the injector cleaning turnaround time. Now the fun starts.
I have a rig to cycle fluid through and pulse the injectors but I don't know what fluid to use to clean them. Most searches turn up the fuel tank additive which I have a feeling may be too volatile and strong to run through injectors as is. Does anyone know what is normally used to clean up the injectors by the fuel injector cleaning services? Some search results showed BG44K(for the on car flushes), kerosene, mineral spirits, gas +ATF, on and on and on.... Andy |
| pnewman |
Mar 27 2014, 12:23 PM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
I need to clean up some injectors for a daily driver Volvo. I would normally send them out but the car is driven every day and the driver can't/won't drive a manual car so there is nothing for them to use during the injector cleaning turnaround time. Now the fun starts. I have a rig to cycle fluid through and pulse the injectors but I don't know what fluid to use to clean them. Most searches turn up the fuel tank additive which I have a feeling may be too volatile and strong to run through injectors as is. Does anyone know what is normally used to clean up the injectors by the fuel injector cleaning services? Some search results showed BG44K(for the on car flushes), kerosene, mineral spirits, gas +ATF, on and on and on.... Andy Try Mr Injectors website: http://www.mrinjector.us/ |
| Bob L. |
Mar 27 2014, 12:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I have not done it myself but I've read some people use Techron from Chevron. It seems get the best reviews from what I have read. I don't know if it is available by itself or as an additive in other fluids. Good luck.
Lo-Fi Version | Time is now: 21st November 2026 - 06:22 PM |
