Real Hot Blue Bosch 12V Coil, How hot is normal???? |
martinef1963 |
Jan 10 2005, 01:56 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
I was tinkering around this weekend trying to isolate the handheld brake light problem I HAD. I turned the ignition on (engine off) and was working the issue. I accidently left the ignition in the on position for about 20 minutes. When I returned to the engine bay and was working on some wire connectors I accidently touched the coil with my hand and it was HOT - very hot.
Can someone tell me if that is normal, or if I should be concerned about anything in particular. thanks, (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
Marlow |
Jan 10 2005, 02:02 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
Whenever I work on my car with the ignition on I always disconnect the coil.
If the points in the distributor are closed when the ignition is on (engine off) the coil is getting power and will heat up. I also heard somewhere that this could lead to damage to the wiring harness if the ignition is left on too long and the points are closed. |
McMark |
Jan 10 2005, 02:07 PM
It can damage your points and will kill a pertronix.
Jan 10 2005, 04:04 PM
Resident German Group: Admin Posts: 41,617 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) all sorts of bad things can happen when you do that ... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Andy |
grasshopper |
Jan 10 2005, 06:12 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
That happened to me once. Something really weird happened. it didn't damage anything but out of no where it blew up. No one else had ever heard of this happening but just watch out. It got really hot before it happened.
SLITS |
Jan 10 2005, 06:13 PM
If you leave the ignition on, with the points closed, the coil will (over) heat to a point where it will explode.....................
And, if you have a VW Bus (early split-window), the coil is aimed right at the gas line from the tank....the hot wires will melt the fuel line, ignite the fuel (which you won't be able to put out) and the fire will eventually get hot enough to start the mag engine case on fire (which you won't put out) and the Forest Service Fire Truck will eventually arrive and they will protect everything from your buring van and after it is all over will tell you that you have a really big tax write off that year. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:51 PM |
