oil line 901.107.331.12 |
Qarl |
Mar 30 2014, 09:18 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I bought my 914-6 oil tank and line years ago from Rich Johnson. Included were all the bits and a number of hoses... namely the hoses from the bottom of the tank to the engine oil cooler.
Also included was the longer 901.107.331.12. http://www.sierramadrecollection.com/store...tail&p=5388 I see this is a 911 part. But I assume that under normal circumstances (without an external cooler) this could be used to go from the tank (bottom right fitting, through the engine shelf) to the oil return on the underside of the engine case? Althgough I'd be worried about that rubber line next to the headers. Looks like Eric Shea has used these for the front-mounted GT oil cooler. Since I'm using a Setrab cooler with AN fittings, I will be making my own lines back to the the engine under the driver's rocker. Does the intended use of this line seem right, or am I missing a use for this line? |
Lo-Fi Version | Time is now: 19th May 2024 - 05:10 PM |
