LEDs For Front Turnsignal Bucket |
mikesmith |
Aug 4 2014, 11:21 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
Rather than bend the leads, just increase the drill size so that the LED sits naturally in the hole at the right angle. Build a jig to hold the board tilted so the LEDs flop over.
This would be a nuisance to set up if you were wave soldering (you'd want a different jig that secured the LEDs at the correct angle), but assuming you're still assembling these by hand (you masochist) it should be simple. With this layout, the low side of the LED should be touching the board, so a generous coating of conformal will bind the LEDs to the board, giving you the mechanical strength you wanted. Also, +1 for a set of the Euros. |
Steve |
Aug 4 2014, 11:34 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Depending on cost, I will take a set of Euro LED's.
euro911 |
Aug 4 2014, 11:57 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Wow, just saw this tonight (IMG:style_emoticons/default/WTF.gif)
Nice (IMG:style_emoticons/default/popcorn[1].gif) Wouldn't it be more like this though, Rob ? E U R O (IMG:style_emoticons/default/poke.gif) ... and I'm in for a pair of EURO units of course (IMG:style_emoticons/default/smile.gif) |
CptTripps |
Aug 5 2014, 07:20 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
If you're worried about vibration, you could always use a rubber grommet at the mount points.
These look awesome, and I'd love a set to match my tail lights too. |
Spoke |
Aug 5 2014, 11:31 AM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Thanks all for ideas on mounting the LEDs. We've been discussing this at work for a while and have come up with several solutions.
Here's one that we've kicked around. This would have a spacer jig to keep the LEDs a uniform distance off the board when soldering. The production jig would encompass all the LEDs at once. This test piece is simply 2 layers of protoboard glued together. I did one LED row and it worked well. Just bent the LEDs until they contact the board. Attached thumbnail(s) |
kid914 |
Aug 5 2014, 02:33 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
(IMG:style_emoticons/default/piratenanner.gif) in for a US set. I still have to order the rears. (IMG:style_emoticons/default/blink.gif)
john77 |
Aug 5 2014, 02:35 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
In for a set to go with my rears.
eric9144 |
Aug 5 2014, 05:02 PM
Advanced Member Group: Members Posts: 2,733 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
In for a US set... (IMG:style_emoticons/default/beerchug.gif)
Spoke |
Aug 8 2014, 10:01 AM
Built up the first prototype; except for 3 white LEDs; need to order more. (IMG:style_emoticons/default/dry.gif)
The jig to bend leads worked well although the angle was slightly too great so the top of the board needs to be deeper than the bottom. Need to adjust the jig so the board can sit flush in the bucket. Attached thumbnail(s) |
euro911 |
Aug 8 2014, 05:25 PM
Jerry, if the upper end of the board sits further down in the bucket, why not just supply a stand-off and a long screw for the upper end? ... or am I missing something ?
Harpo |
Aug 8 2014, 06:21 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Looks awesome Jerry +1 euro
David |
speed metal army |
Aug 8 2014, 10:38 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Yep! In for a set of fronts and rears as soon as the fronts are sorted. (euro fronts,rears)
Nice work. You have wayyy more patience than I do. (IMG:style_emoticons/default/beerchug.gif) |
Spoke |
Aug 10 2014, 09:06 PM
Took a couple of videos of the front LEDs. This is the Euro version.
First the turnsignals; then just the running light. For the turnsignal, the US lens is on. For the running light, the lens is removed. https://www.youtube.com/watch?v=-Go4DQY5T3U Now both the running light and the turnsignal with the US lens off. https://www.youtube.com/watch?v=4y2HTTtBjG8 |
JmuRiz |
Aug 11 2014, 11:51 AM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Is there anyway to turn the running light off when the turn signal is flashing?
The Audis do that, and it makes it easier to notice the flashing signal. Either way, great progress. |
euro911 |
Aug 11 2014, 03:15 PM
In both video clips, are the driver side lamps the stock incandescent bulbs?
I notice a lag to full illumination, whereas the passenger side are a lot quicker and precise (IMG:style_emoticons/default/smile.gif) As far as I'm concerned, the same safety factor applies to the fronts. If they are brighter and easier to see by opposing traffic, they are definitively worth the $ (IMG:style_emoticons/default/idea.gif) |
Chris H. |
Aug 11 2014, 06:41 PM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yep that's what it looks like. I just updated my original post...going US spec. When do you think these will be ready?
IanS |
Aug 12 2014, 09:38 AM
Member Group: Members Posts: 83 Joined: 27-February 12 From: Edmond, Oklahoma Member No.: 14,190 Region Association: Southwest Region |
Those look amazing! I think I already replied in this thread but if not I definitely want a set. I have a US amber front light and no side markers so I guess I would want the non-euro light but I really like the running lights feature.
CptTripps |
Aug 12 2014, 10:06 AM
You know me...I'm in.
Spoke |
Aug 12 2014, 03:33 PM
Jerry, if the upper end of the board sits further down in the bucket, why not just supply a stand-off and a long screw for the upper end? ... or am I missing something ? I'm planning to mount these with brass sheet material like I started on the rear lights. I want to use the existing 2 screws for the lens cover to secure the board. As with the rears, the goal is to make no modifications, drilling, or wire changes to the bucket or lens. I wanted the board to be flush with the bucket angle. This first pair will sit lower in the rear but will work just fine. Just doesn't look as nice as I would like it to. I need to make a jig that is slightly thinner than the one I used for the first board. |
Spoke |
Aug 12 2014, 03:36 PM
In both video clips, are the driver side lamps the stock incandescent bulbs? I notice a lag to full illumination, whereas the passenger side are a lot quicker and precise (IMG:style_emoticons/default/smile.gif) As far as I'm concerned, the same safety factor applies to the fronts. If they are brighter and easier to see by opposing traffic, they are definitively worth the $ (IMG:style_emoticons/default/idea.gif) Yes, the driver side bulb is a standard 1157 bulb. When looking at the flashing of the bulb, when the bulb turns off, its illumination dies quite slowly such that it is almost off by the time the flasher turns back on. The LED is just ON-OFF, no slow turn on or lagging illumination. |
Lo-Fi Version | Time is now: 27th April 2024 - 05:56 PM |
