Dyno Run, Adding Lightness With Megaphones |
wndsrfr |
Apr 3 2014, 07:58 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Took Kermee to Abacus Racing to check AFR's with megaphones on exhaust to add lightness as the muffler must weigh 35 pounds. Got the jets moved to 160's main and 160's air to help avoid going a bit lean at the top end. Had a blast driving it home through the tunnel from Norfolk to Hampton....kid in a newer Camaro had a huge SEG on his face after I got into it in 4th....
Dyno showed that I broke 200RWHP with nice flat torque curve.....Josh sure did a fine job on that 2.7 RS spec build. Heading to Summit Point next then back to VIR in May. Here's the graph.... (IMG:style_emoticons/default/piratenanner.gif) BTW...the difference between the first run and the second is due to removing the K&N filters gained 13 HP......gotta find a way to fit a paper element in there & re-test it..... Attached thumbnail(s) |
JmuRiz |
Apr 3 2014, 08:48 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Very nice! Who did the build again?
2mAn |
Apr 3 2014, 09:00 PM
trying to see how long I can go without a 914 Group: Members Posts: 487 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
that torque curve (IMG:style_emoticons/default/pray.gif)
brant |
Apr 3 2014, 09:32 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Are those 46's?
Somebody has done jetting work. |
brant |
Apr 3 2014, 09:35 PM
Any runs with the other exhaust? Exhaust has a big effect on the dyno and afr
R8CERX |
Apr 3 2014, 09:40 PM
2014 New year resolution: To get along with Woody... Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California |
Took Kermee to Abacus Racing to check AFR's with megaphones on exhaust to add lightness as the muffler must weigh 35 pounds. Got the jets moved to 160's main and 160's air to help avoid going a bit lean at the top end. Had a blast driving it home through the tunnel from Norfolk to Hampton....kid in a newer Camaro had a huge SEG on his face after I got into it in 4th.... Dyno showed that I broke 200RWHP with nice flat torque curve.....Josh sure did a fine job on that 2.7 RS spec build. Heading to Summit Point next then back to VIR in May. Here's the graph.... (IMG:style_emoticons/default/piratenanner.gif) BTW...the difference between the first run and the second is due to removing the K&N filters gained 13 HP......gotta find a way to fit a paper element in there & re-test it..... I have zero restriction out of my K&Ns---it turned out that my ventures were being shocked by the the filter height. I was/am lucky to know the K&N filter company owner, and he set me up with a pair of special made filters for my six--and basically now my car gained the 25 horses it was losing when the filters were on-- you may want to check the increase in height as long as you can keep it under the hood rail.... (IMG:style_emoticons/default/confused24.gif) |
brant |
Apr 3 2014, 09:48 PM
25?
ITG's |
wndsrfr |
Apr 4 2014, 06:28 AM
I was/am lucky to know the K&N filter company owner, and he set me up with a pair of special made filters for my six--and basically now my car gained the 25 horses it was losing when the filters were on-- you may want to check the increase in height as long as you can keep it under the hood Hmmmmmm......I did note that there's very little clearance between the lid and the tip of the velocity attacks....so the filter isn't the issue, it's the height that's the problem? |
R8CERX |
Apr 4 2014, 09:48 AM
I was/am lucky to know the K&N filter company owner, and he set me up with a pair of special made filters for my six--and basically now my car gained the 25 horses it was losing when the filters were on-- you may want to check the increase in height as long as you can keep it under the hood Hmmmmmm......I did note that there's very little clearance between the lid and the tip of the velocity attacks....so the filter isn't the issue, it's the height that's the problem? We increased the gap on top of the velocity stacks- so the lids or filter top were not closing on them When dyno the car I got the full horse power as if I had no filters on! (IMG:style_emoticons/default/cheer.gif) |
ChrisFoley |
Apr 4 2014, 11:12 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:24 AM |
