Took Kermee to Abacus Racing to check AFR's with megaphones on exhaust to add lightness as the muffler must weigh 35 pounds. Got the jets moved to 160's main and 160's air to help avoid going a bit lean at the top end. Had a blast driving it home through the tunnel from Norfolk to Hampton....kid in a newer Camaro had a huge SEG on his face after I got into it in 4th....
Dyno showed that I broke 200RWHP with nice flat torque curve.....Josh sure did a fine job on that 2.7 RS spec build. Heading to Summit Point next then back to VIR in May. Here's the graph....
BTW...the difference between the first run and the second is due to removing the K&N filters gained 13 HP......gotta find a way to fit a paper element in there & re-test it.....
