Fuel Leak at Injector? |
Amphicar770 |
Apr 12 2014, 07:16 AM
Senior Member Group: Members Posts: 1,197 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hi All,
Started up the '74 2.0 for her Spring jaunt. Noticed significant amount of fuel leaking in area of injector (left side, closest to front I think). I figured it was the injector seals so replaced all four of those along with new elbows, clamps, and some other hoses. Started her up and sure enough, leaking from teh same spot. (IMG:style_emoticons/default/headbang.gif) Is this indicative of bad injector, incorrect install (seems hard to do it wrong), or something else. Thanks, Mike |
Michael N |
Apr 12 2014, 07:31 AM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
If you have put in a new seal and that didn't work, you may also want to check the body of the injector. I had a similar issue in the past where the injector developed a small pin hole and was causing the leak.
Apr 12 2014, 08:00 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I had a leak in the same area and it was the only piece of fuel hose that I hadn't replaced previously. The crack was small enough that it would only leak when the car was running and fuel was pressurized.
pt_700 |
Apr 12 2014, 08:09 AM
Senior Member Group: Members Posts: 1,094 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
you kind of need to find exactly where the fuel's coming from.
way back when california started adding ethanol to our fuel, i had to replace all 4 injectors, one at a time, 2 twice! the do develop leaks on the body. far as i know, replacement's the best option. |
brant |
Apr 12 2014, 08:46 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Pull the injector to check. Where it is leaking. I believe you have to replace if it's the body
Amphicar770 |
Apr 12 2014, 06:11 PM
Thanks all. Yes, it turned out to be a bad injector. Fortunately I had an NOS set that I bought a while back. I replaced the two on the side with the leak. Will get to the other side eventually.
My area of the country is also cursed with E-10 fuel (thanks farm lobby) so I am sure that does not help the longevity of these older components. Thanks. Mike |
Lo-Fi Version | Time is now: 9th June 2024 - 04:10 PM |
