buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
I am trying to find out where I bolt down these two pieces to the case but I can't find anything about where the air distributor and air filter support bolts to the case. It looks like the back of the air filter support bolts into the case half bolt in the back of the engine but where does the two front support legs screw or bolt on to?
The air distributor looks to have one place it bolts on to the engine but where? I have the haynes manual, factory manual, pet diagrams, and the search button but can't find anything that describes how these are bolted to the engine. Thanks, Buck |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Not sure about the 1.7, but the 2.0 manifold has a couple of legs that are held by engine tin screws...
And the air filter housing on the 2.0 is held on a bracket that is bolted to the intake runner tubes on the left side. --DD |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Look at PET figure 116-05. You will see a three legged stand for the 1.7L air cleaner as part #1. Two legs connect to engine tin screws and 1 connects to case bolt. When you locate the stand and intake air distributor on the engine, mounting points should be pretty clear...
Lo-Fi Version | Time is now: 17th June 2024 - 06:43 AM |
