100 day countdown, will you be ready for the WCC |
Joe Bob |
Jan 12 2005, 06:07 PM
A-Ron....
i need body work and paint What about the car? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
nebreitling |
Jan 12 2005, 06:17 PM
nahh -- road testing's for wimps!!*
*and pragmatics, realists, and others of wisdom. |
Series9 |
Jan 12 2005, 06:26 PM
aaaaaaahahhhhhhhhh! No pressure.
I only have to: Get a windshield paint the bumpers paint the rockers paint the rear valence finish the interior powder coat the wheels buy tires finish a bunch of detail work get the car aligned and possibly find other-than-carbon fiber decks and get them painted. I'm working on it and I will be there. |
Chris914n6 |
Jan 17 2005, 09:50 PM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
This morning I had a fine, running 914...
now. (IMG:http://www.914resources.com/pics/914n6-01172005.jpg) On my list: make 'glass dash, make 'glass front trunk divider, install climate control system, strip & por15 engine bay, make & mount battery tray ON OTHER SIDE OF BAY, rewire bay, rewire & finish new engine harness, and misc rewire of fuse box & relays. If productivity is my friend... make intake manifold, make headers & new cross pipe. Looking to be the best 3 months of my life (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
TonyAKAVW |
Jan 17 2005, 11:30 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Well, this weekend I crossed off the battery tray. And I simultaneously added and subtracted the hell hole repair as well. In the process of replacing the battery tray I discovered that a small section of the inner wheel house rusted through at the hell hole location. So I welded that up and took the paint off everything else and POR-25'd it.
The optima battery is really solid in there now on a brand new tray. Anyone ever do the front sway bar install without removing the fuel tank? Tony |
nebreitling |
Jan 17 2005, 11:45 PM
probably, but it can't imagine how much more difficult that would be! take out the tank, it only takes about 20 minutes... chris: yikes. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
VegasRacer |
Jan 18 2005, 06:55 AM
ELVIRA Group: Benefactors Posts: 8,500 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Wow Chris. Let me know if you need some help. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) You should have called sooner. I am much better at taking things apart than I am at putting them back together again. (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) |
nine14cats |
Jan 18 2005, 10:16 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Unfortunately Doris and I will not be at the WCC to defend our TTOD Auto-X title. Wait a minute....there is not Auto-X at this year's WCC....so we still have the title (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Our new car won't be ready. It looks like May or June before we take it for it's maiden voyage. Someone should post pics daily for us junkies. Bill P. |
jimtab |
Jan 31 2005, 09:38 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Keep your back to the wall and a sock in your mouth and you'll be ok Mike..... |
jimtab |
Jan 31 2005, 09:40 PM
ME TOO!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) |
Series9 |
Feb 1 2005, 08:06 PM
I made this list today to tape to my tool box. Ouch:
WCC05 Checklist 1 Feb 2005 Engine/tranny: Finish end of main DME harness Strap air filter Clean air filter Tighten fan belt Install clutch helper spring on tranny Retighten CV bolts Install breather relief on the gas tank Distributor vent Body: Rear window (Lexan) Side mirror Retainers for engine grill Compound paint Touch up as necessary Install bumpers Install rockers Install valences Pin front deck Latch for rear deck Seal for front deck Door seals (on door) Rubber stops for engine deck Windshield wiper plugs Fab/install header rain tray w/drain Fab rear trunk panel Install top hardware in trunk Install top hardware on roll bar Repaint faults under header Repaint faults in rear trunk Install new turn signal lenses Fab ‘speaker housings’ Buy/install fog lights Grommets near oil cooler Finalize battery wiring in front Interior: Firewall covering Glue up remaining carpet Install trim panels: windshield, upper hoop, roll bar horiz, roll bar verts Door latches Door panels Paint gauge surround Passenger seat Passenger seat belts Angle bar coverings Interior plugs for trim panels Trim windshield adhesive Final dash attachment Suspension: Plate upper suspension hardware Retighten everything Alignment/ride height Buy tires Powder coat wheels New bolts for front brakes Buy/install new rear coil overs Install sway bar drop links in the rear Buy center caps for wheels |
Mrs. K |
Feb 1 2005, 11:14 PM
Grieve we must, but celebrate a great life! Group: Birthday Fairy Posts: 7,513 Joined: 6-June 04 From: Long Beach, CA Member No.: 2,166 |
I got this one Jenny.....Howard!!! (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Are you really asking to be slapped around.. AGAIN? Lisa (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) |
Joe Bob |
Feb 1 2005, 11:18 PM
Which out fit will you be wearing during the spanking? The one with the thigh high boots? (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Mrs. K |
Feb 1 2005, 11:20 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/lol3.gif) Oh yes, the shiny leather ones! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Lisa (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
TonyAKAVW |
Feb 2 2005, 12:04 AM
Well, this past weekend I crossed off some more items from my list...
Installed front sway bar Replaced stock sagging springs with 140 lb springs Replaced shocks with KillYourBacks from my previous 914 Replaced front brake pads Replaced front brake lines Replaced tie rod ends New rubber lines for the gas tank Still have to get rid of the oil leak which means new valve cover gaskets and pushrod tube o-rings. -Tony |
Lo-Fi Version | Time is now: 4th May 2024 - 04:24 PM |
