Picked up a 912, opinions? |
McMark |
May 4 2014, 09:20 AM
I agree with going to a six.
But I make some mounting stuff for the conversion which is based on the 912E stuff. You can use the bus engine bar and the stock engine mounts. But the 912E style system removes about 5-8" of height from the engine bar to body mount span. Using the stock body mounts with the type 4 results in a long U shaped mount bar. This tends to allow the motor to shift forward/backward in the car because it has so much leverage. It works. I've done it. But it's not great and will chew up transmission mounts pretty quickly. Add body mounts below the frame rail and you'll be much better off. Attached image(s) |
KELTY360 |
May 4 2014, 09:21 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Thanks for the links. On ebay right now: This awesome car seems to utilize the bus motor mount. http://www.ebay.com/itm/Porsche-912-912-91...=US_Cars_Trucks Barnum was right. |
thomasotten |
May 24 2014, 01:21 AM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Since I am leaning towards a six, what is conventional wisdom as to the largest motor that I could install and still use the original gearbox?
Another related question. This is a SWB car. I presume that means I must stay with a SWB transmission. I want a fairly straightforward six conversion. |
May 24 2014, 02:26 PM
Andy's got a 993 3.6 liter in front of a 901-based 914 gearbox... It will work as long as it's in good shape and you don't abuse it.
--DD |
thomasotten |
May 28 2014, 06:54 AM
Thinking of doing a 2.4 Liter or 2.7 Liter 911 engine install, and keeping the fuel injection system intact. Do these engines require an ECU or brain box similar to the 914's fuel injection system? I other words, if I buy one of these engines, is there some electronics that I need to make sure I acquire as well? |
JmuRiz |
May 28 2014, 07:45 AM
914 Guru Group: Members Posts: 5,424 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
2.4 CIS and 2.7CIS do not have a brain. They are very simple systems. If you have a 2.4 with carbs they are super simple as well, the 2.4 MFI are complex but do-able if they MFI is tuned correctly.
Steve |
May 28 2014, 12:30 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I would do a 2.4-2.7 if you want to stay with the stock trans. 3.2-3.6 you will end up starting off in second and more or less only have a 4 speed. 2.4-2.7 you can use an early 2.0 flywheel and stock clutch. I loved my 2.7 with webers and the stock trans.
thomasotten |
May 28 2014, 06:28 PM
So the 2.4 and 2.7 do not have a brain box like the 914 fuel injection? So then it is pretty simple bolt on then, huh? Do you need an external oil cooler for either 2.4 or the 2.7?
JmuRiz |
May 28 2014, 06:46 PM
Need...no, want...yes (IMG:style_emoticons/default/smile.gif)
bigkensteele |
May 28 2014, 06:59 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
If you decide to go with a T4, I have a set of engine tin that I have pulled off my 2.7 donor which could be used to fashion a set for your conversion. I would be glad to donate to your cause.
If you go with a 2.7, look for a '74. They did not have the thermal reactors that caused the later engines to bake themselves. Most have been rebuilt by now, but I have been told is that a '74 is what you want to start with. |
May 28 2014, 09:13 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I agree with going to a six. But I make some mounting stuff for the conversion which is based on the 912E stuff. You can use the bus engine bar and the stock engine mounts. But the 912E style system removes about 5-8" of height from the engine bar to body mount span. Using the stock body mounts with the type 4 results in a long U shaped mount bar. This tends to allow the motor to shift forward/backward in the car because it has so much leverage. It works. I've done it. But it's not great and will chew up transmission mounts pretty quickly. Add body mounts below the frame rail and you'll be much better off. Mark, IC a tubular bar that maybe you made.....got that. What is the cast part? Is that a stock bar from a 912e? Is that a specific part that can be purchased? |
May 28 2014, 10:11 PM
So the 2.4 and 2.7 do not have a brain box like the 914 fuel injection? None of the 911s have a brain box until you hit the Motronic injection with the 1984 3.2 Carreras. No electronic injection at all until then. At some point--probably 1980?--the CIS cars had a "frequency valve" that was an electric gizmo controlled by the O2 sensor which fiddled the CIS mixture. But that's not the same as a "brain box". --DD |
euro911 |
May 29 2014, 12:58 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'm just finishing up a '68 616 (912) motor that I was going to stick in my wife's '67 bug, but we decided to sell the bug (as-is).
Not sure if I'm going to sell the motor or keep as a spare for my '66 912 (IMG:style_emoticons/default/confused24.gif) Sounds like you're leaning towards a '6' anyway. Go with the 2.7L (IMG:style_emoticons/default/aktion035.gif) |
jcd914 |
May 29 2014, 02:21 AM
So the 2.4 and 2.7 do not have a brain box like the 914 fuel injection? None of the 911s have a brain box until you hit the Motronic injection with the 1984 3.2 Carreras. No electronic injection at all until then. At some point--probably 1980?--the CIS cars had a "frequency valve" that was an electric gizmo controlled by the O2 sensor which fiddled the CIS mixture. But that's not the same as a "brain box". --DD Except if by "brain box" you mean the typical looking Bosch control unit with a 25 pin connector that controls the frequency valve. 1980 thru 1983 911 SC's used the the O2 sensor & frequency valve and the control unit that came with them. Jim |
cmpski |
Jul 5 2014, 09:42 PM
Newbie Group: Members Posts: 12 Joined: 19-June 14 From: Arvada, Colorado Member No.: 17,508 Region Association: Rocky Mountains |
www.PompoloDesign.com
2.4 liter 3.0 to 3.2 torque 180 rear wheel hp. Close to 2.7 RS gross hp. 100 pounds lighter than a 6. 6 to 8 inches shorter for better weight distribution. This helps alot on the early SWB cars. Expensive but worth it. About the same price as a quality 911 rebuild. Built by Dean the designer, RUF, Craig Smith, Canepa, Rothsport, Jerry Woods, and others. Handles like a 912 and goes like a 911. Chris Attached thumbnail(s) |
barefoot |
Jul 6 2014, 07:10 AM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
So the 2.4 and 2.7 do not have a brain box like the 914 fuel injection? None of the 911s have a brain box until you hit the Motronic injection with the 1984 3.2 Carreras. No electronic injection at all until then. At some point--probably 1980?--the CIS cars had a "frequency valve" that was an electric gizmo controlled by the O2 sensor which fiddled the CIS mixture. But that's not the same as a "brain box". --DD YES, 1980 911SC was first year (in USA) to use O2 Lamda sensor to adjust fuel mixture with feedback system. |
funk |
Jul 19 2014, 10:46 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
realistically place a 914 in the same condition next to this 912 and from restoration design prices the panels aren't much more to do a solid stock conversion. go with a talented old school vw mechanic to rebuild and you can pump up the volume without the raby hype and price !! (IMG:style_emoticons/default/WTF.gif)
BK911 |
Jul 20 2014, 10:05 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Recently picked up a 69 912. The stock 4 has plenty of power to zip around the local roads. No need for -6 power.
euro911 |
Jul 20 2014, 11:16 AM
Recently picked up a 69 912. The stock 4 has plenty of power to zip around the local roads. No need for -6 power. Awesome. The reduction in weight coupled with a more centralized weight distribution makes the 912 pretty nimble, and will give a 2.0L T '6' of the same vintage some serious competition. If you ever get the opportunity, see what a mere increase to 1720cc does (IMG:style_emoticons/default/aktion035.gif) Congrats (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:11 PM |
