Flapper boxes |
Flapper boxes |
ipadstott |
Apr 20 2014, 08:03 AM
Ian Stott Group: Members Posts: 27 Joined: 2-April 14 From: Moncton Canada Member No.: 17,192 Region Association: Canada |
Need new ones, does anyone redo these? Thought I saw something on that a while ago. Pelican is listing them but out of stock. Nice to have heat where I live!
Ian Stott Moncton Canada |
barefoot |
Apr 20 2014, 08:31 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I have a spare left side P/N 022 256 205A. Been media blasted and painted with 900 degree HT flat black paint.
Photo if needed. Barefoot |
ipadstott |
Apr 20 2014, 08:38 AM
barefoot |
Apr 20 2014, 08:40 AM
I have a spare left side P/N 022 256 205A. Been media blasted and painted with 900 degree HT flat black paint. Photo if needed. Barefoot Are they the same for all years? Mine is a 73 2.0 Ian Stott Moncton Canada I think so. I can take photo so you can compare to whatever you have left. |
Johny Blackstain |
Apr 20 2014, 03:51 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
If you have a welder you can order cheap new ones for a VW bus, from JC Whitney. Grind off the weld on top of the control arm, spin it 145 degrees & weld it back in the new, correct place. Blue tape is @ 145 degrees from the current position of the arm.
Attached thumbnail(s) |
ipadstott |
Apr 20 2014, 03:54 PM
If you have a welder you can order cheap new ones for a VW bus, from JC Whitney. Grind off the weld on top of the control arm, spin it 145 degrees & weld it back in the new, correct place. Blue tape is @ 145 degrees from the current position of the arm. Thanks Johnny, way beyond my abilities! Appreciate the tip though. Ian Stott Moncton Canada |
Johny Blackstain |
Apr 20 2014, 04:03 PM
Thanks Johnny, way beyond my abilities! Appreciate the tip though. Ian Stott Moncton Canada (IMG:style_emoticons/default/welcome.png) Ian, it's not a big deal @ all. You can order 2 new ones from Whitney, mark them where they need to go & then either grind off the weld yourself or have it done @ the shop where you take it to be re-welded. It's a simple spot weld or 2 & would take 10 minutes for both. Originals & the ones for the bus are both manufactured by Dansk & the only difference is the price & where the arm is welded. |
barefoot |
Apr 20 2014, 06:26 PM
ripper911 |
Apr 21 2014, 05:37 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
bcheney |
Apr 21 2014, 08:09 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
I have a set for sale in the classifieds. Solid with only surface rust. Fully functional and you can knock down the surface, clean and shoot with some hi temp paint, install and be warm again.
mrholland2 |
Apr 21 2014, 09:21 AM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
ChrisFoley |
Apr 21 2014, 10:10 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'd prefer good used over new replacement.
The new ones are made for buses, not 914s. There's a bit more of a difference than simply reclocking the arm. Ian, if needed, I can sell you new ones off the shelf and we can do the mods here. |
ipadstott |
Apr 21 2014, 02:53 PM
I'd prefer good used over new replacement. The new ones are made for buses, not 914s. There's a bit more of a difference than simply reclocking the arm. Ian, if needed, I can sell you new ones off the shelf and we can do the mods here. That's great Chris, I need 2, see you in a few weeks, I plan on staying overnight so if you could recommend a reasonable and clean motel close to you that would be appreciated. Ian |
Johny Blackstain |
Apr 21 2014, 02:59 PM
The same one I posted yesterday, after I ground down the weld today & used my horrific, atrocious, piss poor welding skills on it. (IMG:style_emoticons/default/laugh.gif)
ChrisFoley |
Apr 21 2014, 03:29 PM
Here's a comparison between a 914 and a bus flapper.
Not only is the arm at a different angle, the tube for the hose to body connection is at a different angle as well. |
ipadstott |
Apr 21 2014, 03:33 PM
Here's a comparison between a 914 and a bus flapper. Not only is the arm at a different angle, the tube for the hose to body connection is at a different angle as well. Good thing I'm bringing a truck! Wife wants me to pick up a dining room set while I am stateside, can't get what she wants in Canada! |
Johny Blackstain |
Apr 21 2014, 03:34 PM
Lo-Fi Version | Time is now: 4th May 2024 - 09:59 AM |
