Flapper boxes |
Flapper boxes |
ipadstott |
Apr 20 2014, 08:03 AM
Ian Stott Group: Members Posts: 27 Joined: 2-April 14 From: Moncton Canada Member No.: 17,192 Region Association: Canada |
Need new ones, does anyone redo these? Thought I saw something on that a while ago. Pelican is listing them but out of stock. Nice to have heat where I live!
Ian Stott Moncton Canada |
Johny Blackstain |
Apr 20 2014, 03:51 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
If you have a welder you can order cheap new ones for a VW bus, from JC Whitney. Grind off the weld on top of the control arm, spin it 145 degrees & weld it back in the new, correct place. Blue tape is @ 145 degrees from the current position of the arm.
Attached thumbnail(s) |
ipadstott |
Apr 20 2014, 03:54 PM
If you have a welder you can order cheap new ones for a VW bus, from JC Whitney. Grind off the weld on top of the control arm, spin it 145 degrees & weld it back in the new, correct place. Blue tape is @ 145 degrees from the current position of the arm. Thanks Johnny, way beyond my abilities! Appreciate the tip though. Ian Stott Moncton Canada |
Johny Blackstain |
Apr 20 2014, 04:03 PM
Thanks Johnny, way beyond my abilities! Appreciate the tip though. Ian Stott Moncton Canada (IMG:style_emoticons/default/welcome.png) Ian, it's not a big deal @ all. You can order 2 new ones from Whitney, mark them where they need to go & then either grind off the weld yourself or have it done @ the shop where you take it to be re-welded. It's a simple spot weld or 2 & would take 10 minutes for both. Originals & the ones for the bus are both manufactured by Dansk & the only difference is the price & where the arm is welded. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:11 AM |
